Rod Inside Steering Column
Old Mar 2, 2019 | 07:48 PM
Black_C4's Avatar
Black_C4
Default Rod Inside Steering Column
Hello yall from Charleston SC! I have a 91 Coupe with the automatic.
Im venturing well outside of my comfort zone with this project, I dont mind challenging myself. I am a professional motorcycle mechanic. And used to build Honda race cars (yeah, yeah).
I am working on a few issues in the steering column, floppy turn signal stalk, replacing the ignition lock, and removed the cluster to send out for repair.
I can tell someone who didnt know what they where doing was in there before. And I am questioning whether this rod (circled in attach pic) is not where it is supposed to be. Im looking for some insight and/or where I can find some pics or good info on the steering column internals. I will be downloading a service manual tonight as well.
Thanks in advance for any help!
Old Mar 2, 2019 | 08:12 PM
belairbrian's Avatar
belairbrian
it's the high beam low beam dimmer rod
Old Mar 2, 2019 | 08:17 PM
belairbrian
here's a link to the Illustrated Parts Breakdown
91 Steering Column IPB
Old Mar 3, 2019 | 04:24 PM
csthews's Avatar
csthews
There is a plastic switch rod actuator that goes between the rod and the multi-function switch. If it is missing, that answers why your stalk is loose.
Old Mar 3, 2019 | 04:37 PM
Black_C4's Avatar
Black_C4
Its defiantly missing lol The rod was just chillin in there!
Thanks for the hint. Now I have to find one of those. Would it happen to be #21 or 22 in the above parts diagram?
Old Mar 3, 2019 | 07:25 PM
belairbrian
It's part 21 it's just a piece of plastic and just sits in there. 22 is the pivot pin for the washer switch.
Amazon Amazon
Old Mar 3, 2019 | 09:23 PM
csthews's Avatar
csthews
One more thing. It is not unusual for these cars to have a little (or a lot) of left-right wobble in the steering column which is the result of people using the steering wheel to get in and out of the car. If that is the case, you might want to address that while you have the steering wheel off. If you don't address it, that switch rod actuator may fall off again, and if it does, it is really tough to get back in place with the steering wheel in place. Ask me how I know. There are numerous posts here on the steering wheel movement. Also, make sure no one uses the steering wheel as leverage to get in/out of the car.
Old Mar 10, 2019 | 07:53 PM
Black_C4's Avatar
Black_C4
Ok, Ive got the dimmer rod and the plastic piece figured out. Also tightened up the column/tilt bolts.
Next, back to the original reason I pulled this mess apart. Im dealing with the floppy stalk issue. My switch assembly isnt broken. The actuator Dosent seem to stay in the mechanism unless I put pressure on it with my hand.
Ive studied the diagram and manual as best I can, I do not see anything missing or broken. Ive re-installed the lock ring and retainer clip to see if that would hold enuff pressure on the assembly to keep the actuator in place, no dice.
The actuator dosent seem bent, but I may try to tweak it slightly. But I wanna ask here first lol Im not a fan of "Bubba" fixes
Old Mar 11, 2019 | 06:29 PM
belairbrian
Where is the play? between the turn signal switch (yellow part) and the actuator (metal part in last pic). when the actuator is screwed in those two should move as one.
Which switch assy is not broken, the turn signal switch or the wiper switch? If the guide on the wiper switch is broken the lever flops down.
Old Mar 11, 2019 | 09:10 PM
Black_C4's Avatar
Black_C4
The titty (sorry) on the actuator dosent stay in the guide on the stalk part. The little circle, inside the big circle.
The signal cam and springs are ok.
Im just gonna replace the signal switch as well. Then everything will be new lol
Old Mar 12, 2019 | 06:15 PM
csthews's Avatar
csthews
Are you sure you have the bottom end of the switch rod firmly seated in the actual dimmer switch?
Old Mar 12, 2019 | 08:04 PM
Black_C4's Avatar
Black_C4
Yes sir. The dimmer rod was actually easier than it was made out to be to install lol
The whole setup isnt that complicated after Ive installed it all. Thats why Im kinda confused lol
Im perfectly happy "just throwing parts at it" since its my ride. I have a tendency to do that with my projects, since everything will be new when Im done. I absolutely dont treat customers rides the same way lol
Im ordering a wiper switch and will install that next. Seems to be the only other option.
Old Mar 24, 2019 | 07:58 PM
Black_C4's Avatar
Black_C4
Well, not to leave this post unanswered, I figured my situation out. The hard (expensive) way.
I replaced the wiper/washer multifunction switch, which are getting hard to find in 2018. Got mine for $200 from OReillys.
Replaced the turn signal cam/switch assembly. And the aggravating little plastic dimmer slide or whatever its called. Even installed a new ign lock, while I was in there lol
Turned to to actually be that metal fork, actuator. In the above picture, the little yellow circle inside the large circle, you can see the space. The end of the little fork that fits into the multifunction switch, was tweaked slightly. I bought this car from a mechanic who got it from someone with blown head gaskets lol So who knows.
Tweaked the end farther towards the slide where it fits into.
To Rod Inside Steering Column
