Key fob
Old Mar 6, 2019 | 04:04 PM
astro5169's Avatar
astro5169
7th Gear
Default Key fob
Are there any key fob. Replacement ?
Old Mar 6, 2019 | 04:34 PM
Polo Vert's Avatar
Polo Vert
I've seen new ones on Ebay, but they're not cheap.
Old Mar 7, 2019 | 11:47 AM
markKlein's Avatar
markKlein
You can get new ones on ebay, around 130-150. There is one model for coupes and one for verts. But before you buy one make sure the receiver/module in your car is still working. Perform the test to program a fob to your car (in the owners manual) right up until you need to have the fob present. If the light begins blinking it is safe to assume the onboard functions are OK. If not no point buying a fob until/unless the existing problems are fixed. Also, read the PKE section carefully to make sure you understand how the system works.
To Key fob
