New to vette world and forum. I have a 93 LT1 40th anniversary vette. Never had any trouble but LOTS of fun driving. Today went out n the vette ran good until it started run very rough n died. If I let it sit awhile it would start n get me a few miles before dieing again. Took me awhile to get home. Any idea what the issue can be?
Not yet just occurred today and wasn't sure where to begin. It will start and run for a few miles, so assuming not fuel, when it is running it will run smooth for a few miles. Not sure what would cause it to suddenly die.
I don’t want to be the bearer of the “big O “ bad news, but both my Lt 1’s ( a 92 and a 93 Ruby ) both exhibited those exact same symptoms as they were circling the drain. Then died completely.
The first thing I would personally check for is spark to and from the optipsark unit. This checks the coil and ignition control module as well as the opti. This would be a good place to start as the optispark has a moderate failure rate. Most every LT1 owner will experience replacing one or having theirs replaced at some point. In addition to this, of course, a fuel pressure test would be in order and it can't hurt to scan the ecu for stored codes. Keep us updated with what you find.
I completed the paper clip method to locate any codes. In Mod 4 I received H16 and H36. From the search I completed, it looks like a bad opti like everyone had mentioned. Looks like I have to replace the opti and might as well change water pump.
This forum has been extremely helpful and looking forward to getting the 93 Back on the road.
Thanks to All!
Good job on learning how to scan the codes
They will give codes with: H or C in front of the numbers. H is for history, C is for current. When the car dies, connect noid light to any fuel injector connector. No pulsing when cranking=bad opti.
I believe local auto parts store will loan a mood light set. Thanks I will make that my next task. If I need the opti any advantage to upgrading from stock? If so which brand?
