Injector changeout
Old Mar 20, 2019 | 10:23 AM
MarkLiberty's Avatar
MarkLiberty
2nd Gear
Default Injector changeout
Any suggestions for helpful threads as I get ready to install a set of Bosch III's ....? Pictures would be helpful....maybe a good video....or just plain English instructions. Thanks..!
Old Mar 20, 2019 | 11:19 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Wash down the injector area and blow dry with compressed air to remove any debris.
Give each injector a shot of oil to loosen the now hard o-ring. and let sit for a few minutes
Pull and replace.
GL
Old Mar 20, 2019 | 02:14 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Helps to park nose up-hill, then FP fuse and run engine "dry" of fuel.
I always bag & label all bolts & screws to aid in reassembly.
A little Si grease on the O-rings aids in reassembly with minimal risk to the rubber.
As mentioned, clean area before opening up engine top.
To Injector changeout
