Code P36
Old Mar 28, 2019 | 06:28 AM
Masonrw89's Avatar
Masonrw89
7th Gear
Default Code P36
I own a 1989 C4 Corvette with 54,000 miles and the problem I’m having is that it keeps tripping a Code 36. My mechanic and I have gone through the procedure in the shop manual and everything checks out, but yet it still trips. We have disconnected the battery and it clears but after maybe 6 times of starting it it will throw the code. Also dose out hurt the engine to drive it with the code tripped? Please tell me you have a fix for this?
Old Mar 28, 2019 | 10:00 AM
Kevova's Avatar
Kevova
Have you replaced both MAF relays ?
Old Mar 28, 2019 | 04:23 PM
Masonrw89's Avatar
Masonrw89
7th Gear
Default Code P36
Yes, and the MAF and the plug to the MAF.
Old Mar 28, 2019 | 04:57 PM
Kevova's Avatar
Kevova
Oiled filters ( K&N Amsoil, etc) can cause trouble with film in sensor. A known good sensor would be good. Sensor from a car that doesn't have codes to drive with long enough to confirm car or sensor. It's possible problem is with ECM.
Old Mar 28, 2019 | 06:16 PM
Masonrw89's Avatar
Masonrw89
7th Gear
Default Code P36
I have a OEM dry style air filter.
Old Mar 30, 2019 | 12:21 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Are all electrical connections to the relays & MAF solid with no corrosion?
Old Mar 30, 2019 | 06:57 AM
Masonrw89's Avatar
Masonrw89
7th Gear
Default Code P36
Yes they are clean
To Code P36
