help with these two stamped metal harness brackets please!!
Old 04-21-2019, 05:24 PM
VikingTrad3r
Oil Producer
Support Corvetteforum!
VikingTrad3r's Avatar
Received 2,270 Likes on 1,452 Posts
Default help with these two stamped metal harness brackets please!!
1986 4+3 e
I stupidly removed these components from the bags and now I’m not sure where they belong? I have much of the dryer line undone, I believe the one with the plastic clip is the lower driver side bell housing bolts that hold the harness coming back to the 4+3 electronics.
The other one that is longer and has no plastic on it in the photos I have no idea where it goes. Any help?
No idea where this one goes
Old 04-21-2019, 05:57 PM
WVZR-1
WVZR-1's Avatar
Received 2,271 Likes on 2,032 Posts
Try #13 for longer and just left of center closer to top of clutch housing for short with loom clip.
Old 04-21-2019, 10:35 PM
VikingTrad3r
Oil Producer
Thank You Wvzr1, i have looked through my 86 fsm and cant find this diagram. thanks.
Old 04-21-2019, 11:04 PM
WVZR-1
WVZR-1's Avatar
That's from a GMSPO parts catalog
** The short may actually not be the one I pointed out. If that one (on your car) is accounted for wrapped/taped in harness then move on.
Old 04-21-2019, 11:39 PM
VikingTrad3r
Oil Producer
thanks for the further detail. based on the shared image, im confident the long bracket is a match, and im sure the short with loom clip goes bottom driver side on bellhousing.
thnx.
To help with these two stamped metal harness brackets please!!
Quick Reply: help with these two stamped metal harness brackets please!!
