Lower rear differential HELP
Old May 2, 2019 | 10:10 PM
Jarimee's Avatar
Jarimee
1st Gear
Default Lower rear differential HELP
Need some input I need to lower the rear pumpkin and was wondering if you use a lowering kit would that drop the pumpkin ?
Old May 3, 2019 | 06:51 AM
Klondike's Avatar
Klondike
As many things that you have to get out of the way anyway ; exhaust, C-beam, inboard U-joints... it’s just as easy to take the bat- wing down with the rear ended still attached. It’s a lot easier to get at everything with it all out of the car. Not nearly as hard as you might think.
Old May 3, 2019 | 11:06 AM
Kevova's Avatar
Kevova
Lowering kit doesn't drop "pumpkin" it stays attached to the body in the same position. You could say suspension moves up in the body. You could remove spare carrier if you want pumpkin to be more visible.
Service: I would drop out diff with batwing. Mostly because resealing cover is easier on a table.
Old May 3, 2019 | 08:10 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
I am confused are you trying to remove your differential or lower the car
To Lower rear differential HELP
