Need electrical help
Old May 8, 2019 | 06:35 PM
mlm0's Avatar
mlm0
Default Need electrical help
1889 automatic stock
Down behind the battery is a fuse that is wired into the positive red wire coming directly off the battery. I don’t know where the other end goes to. I was checking mine because of an electrical problem when it fell into that never never land when I disconnected it. I never saw it so I don’t know what it looks like, size and I can’t seem to find anything about it in my FSM. Can anyone help me out?
Old May 8, 2019 | 07:46 PM
mlm0's Avatar
mlm0
I found a little more information. In the FSM on page 8A-10-0 is the power distribution lay out. The fuse is labeled ( fusible link H ) it’s really a replaceable fuse. It says .5 Rust. I have no idea what that means. It appears to be the main line for most power including the ecu, which explains why I have no power to car
hope this helps someone to be able to help me. I’m kinda in panic mode which doesn’t happen to me very often
Old May 8, 2019 | 08:48 PM
mlm0's Avatar
mlm0
DISREGARD MY POSTING. problem solved. I just need to learn to take a break when I get tired
Old May 10, 2019 | 12:08 AM
Logan Shoemaker's Avatar
Logan Shoemaker
6th Gear
Well feel free to say what you did at least hahaha.
Old May 10, 2019 | 02:58 PM
mlm0's Avatar
mlm0
No no no. I would b kicked out of forum for being so stupid
To Need electrical help
