Cigarette lighter question
EDIT: I found this on the internet....Take a rag, and stick it down into the lighter socket, and then stick your finger in it. That should give enough grip on the socket itself to remove the lower retainer. It does just screw on, and it holds the assembly to the console panel. Sometimes they can be a pain, other times, you can't keep them tight! This should get it disassembled
Can it really be that easy?
