ALDL connector location?
Old Nov 6, 2002 | 10:33 PM
GlobalGreg's Avatar
GlobalGreg
Default ALDL connector location?
I had taken off my lower trim panel and I had to unhook my ALDL connector and tucked it underneath the knee bolster and just forgot about it, now for the life of me I can't find where it screws back on!! Can someone take a pic for me or explain for me in detail where it goes? Thanks!
Old Nov 7, 2002 | 01:52 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: ALDL connector location? (GlobalGreg)
What year? The one on my '92 has a snap-on plastic cover, not screws. It's located under the dash, under the steering column area I believe.
I always have to scoot the sports seat waaayyyy back to get to it. Not very user-friendly, but handy for troubleshooting. :yesnod:
Old Nov 7, 2002 | 04:48 PM
GlobalGreg's Avatar
GlobalGreg
Default Re: ALDL connector location? (onedef92)
It's for my '93. Maybe I worded the question wrong, sorry. I know where it is located, I've used it many times. I have unscrewed the whole thing completely from the trim but I can't find where it screws back on, it's just hanging if it's not tucked underneath the knee bolster.
Old Nov 7, 2002 | 08:13 PM
thrills's Avatar
thrills
Moderatrix
See if you can actually fit your upper body under there with a flashlight and you can see the holes. It's much easier with the seats out though :D
Old Nov 7, 2002 | 08:21 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
It's actually one screw, to reinstall it properly, you will have to remove the hush panel again, the you will see the hole where the screw goes in.
Old Nov 8, 2002 | 05:48 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Taking pics now...
Hope that helps! :cheers:
[Modified by 92Shawnster, 5:28 PM 11/8/2002]
Old Nov 8, 2002 | 08:43 PM
GlobalGreg's Avatar
GlobalGreg
Default Re: ALDL connector location? (92Shawnster)
Thanks a ton!!!!!!! You went through a lot of trouble for that it looks like. Now I finally know where it goes hehe Thanks again.
Old Nov 12, 2002 | 01:22 PM
ShawnZR-1's Avatar
ShawnZR-1
Nah, I had the dash pad out hunting down another problem and I remembered your post. Glad I was able to help though! :cheers:
[Modified by 92Shawnster, 1:24 PM 11/12/2002]
To ALDL connector location?
