oil change life monitor Turn key on do not start engine ,press eng met button on trip monitor and release ,then with in five seconds press and release eng met button, again. with in five seconds press and hold GUAGE button ( the change oil lite will flash) Hold the GIAGES button until Change oil lite stops flashing and lite goes out! When the light goes off monitor is set.
1. Turn the key to the "ON" position, but don't start the engine. 2. Press the ENG/MET button on the Trip Monitor and release it. Then, within five seconds, press and release the ENG/MET button again. 3. Within five seconds, of Step 2 1990 – 1991 , press and hold the RANGE button on the Trip Monitor. 1992 -1996 , Press and hold the GAUGES button on the Trip Monitor. 4. The CHANGE OIL light will flash. 5. Hold the RANGE or GAUGES button until the CHANGE OIL light stops flashing and goes out. When the light goes out, the Engine Oil Life Monitor is reset. This should take about ten seconds.
If it doesn't reset, turn the ignition "OFF" and repeat the procedure.
