87 no brakes
Old Jun 29, 2019 | 05:16 PM
stevic's Avatar
stevic
Cruising
Default 87 no brakes
Hi Everyone;Brake pedal went to floor last Sunday. I replaced the master cylinder
and bled everything , pedal still goes to the floor, what's next? Thanks!
Old Jun 29, 2019 | 07:42 PM
J W Drew's Avatar
J W Drew
Take the Master Cylinder back. Most likely got a bad one.
Old Jun 29, 2019 | 09:42 PM
stevic's Avatar
stevic
Cruising
Thanks JW, 2 hrs of bleeding down the drain.
Old Jun 30, 2019 | 01:05 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You can pre-bleed the master so very little air is introduced into the system.
Old Jun 30, 2019 | 07:13 AM
stevic's Avatar
stevic
Cruising
Thanks 65Z01-I did bench-bleed that master cylinder-Went to Advance Auto and got a $26 dollar hand operated
vacuum pump and it's a piece of junk
Old Jul 1, 2019 | 01:03 PM
stevic's Avatar
stevic
Cruising
OK-this morning I pulled the new master cylinder off, checked operation it's ok, bench bled it, bled everything on the car, now the pedal will only go to the floor
after 4 or so pumps. Any thoughts?
Old Jul 1, 2019 | 01:30 PM
stevic's Avatar
stevic
Cruising
Next question-- Do I have to bleed the ABS unit?
To 87 no brakes
