Engine Problem
Old Jun 29, 2019 | 04:47 PM
jag pilot's Avatar
jag pilot
5th Gear
Default Engine Problem
1995 lt1 engine. the starter labors to start when engine is hot.
Old Jun 29, 2019 | 09:00 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Check your battery condition. You may need a new one.
Old Jun 29, 2019 | 09:06 PM
jag pilot's Avatar
jag pilot
5th Gear
Thank you. Will check tomor
Old Jun 29, 2019 | 09:42 PM
95LT1ZF's Avatar
95LT1ZF
I had a starter on a 79 Z28 that used to get heat soak for a few weeks before I finally replaced it. Battery would be my first place to check though
Old Jun 30, 2019 | 11:17 AM
Paul Workman's Avatar
Paul Workman
w/ the above (battery check). But, I also experienced a very labored starting phenomenon when restarting when hot. Turned out to be the STARTER. It worked fine when cold. The shop told me "no problem found". But, they didn't test the damn thing when it was HOT. That's when the issue showed up (common to electrical windings when they fail. "Thermal-related", as it were)...
Old Jul 2, 2019 | 01:21 PM
Hot Rod Roy's Avatar
Hot Rod Roy
If the starter pinion gear is too tight against the ring gear, there will be excessive load on the starter, which could cause your problem.
To Engine Problem
