Headlight problems
Old Jul 7, 2019 | 02:09 AM
Kellie Webster's Avatar
Kellie Webster
2nd Gear
Default Headlight problems
Just bought 84 corvette headlights come on then 5 seconds light goes out. Had alternater tested thats fine. Please help loosing my mind.
Old Jul 7, 2019 | 03:11 PM
Kevova's Avatar
Kevova
Stock or HID/LED headlights?
Old Jul 7, 2019 | 04:39 PM
fparkin's Avatar
fparkin
bad headlight switch or connection at lights
Old Jul 10, 2019 | 01:31 PM
Jimrobski's Avatar
Jimrobski
Anytime you have wiring to a moving part, you can develop problems.
Check for loose connections.
Then check for a break in the wiring somewhere.
Old Jul 10, 2019 | 06:42 PM
Gibbles's Avatar
Gibbles
Headlight switch has a breaker in there.
Careful, it's like an inch away from a big sheet of styrofoam (flammable!)
You need to pull the dash pad to change the switch.
Also the 84 runs the fog lights through the switch, if you put too much load on there...
My headlight switch smoked at one point, when i removed it i was pretty sure there was a small fire for a few seconds.
To Headlight problems
