Speedometer too fast
Old Jul 23, 2019 | 11:16 AM
colo63sw's Avatar
colo63sw
Default Speedometer too fast
My speedo flipped out the other day. The speed now reads too fast.
Crawling across a parking lot it reads 12 MPH; at about 45 actual speed it reads 75 MPH. The speed delta is consistent, it’s not jumping around, like reading 0 when I am driving. The cruise control works, it maintains speed that is displayed. Speedo does the same reading if it is cold or hot.
Can I rule out the VSS on this? Does the VSS simply change gear rotation to RPM signal? My guess is that the VSS sends a RPM signal to a chip somewhere that does the calculation RPM * X, Y, or Z (based on current trans gear) = MPH.
Car is stock 1993 with automatic.
Any help is appreciated.
Old Jul 23, 2019 | 01:38 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Sounds like you may have accidentally hit the button that changes the MPH to KPH. (if divide 45 by 0.6 you get 75)
Old Jul 23, 2019 | 02:40 PM
colo63sw's Avatar
colo63sw
Thanks. That is a great suggestion! My mind is too focused on VSS & ECM's.
ENG / MET button.... DOPH!
I'll let you know how that works out.
Old Jul 24, 2019 | 10:59 AM
colo63sw's Avatar
colo63sw
I'll follow up this way...... I am going to put on the Dunce cap and sit in a corner for a while.
Old Jul 24, 2019 | 03:10 PM
Mr. Peabody
Look at it this way. Aren't you glad that all you had to do is push a button rather than go digging into the trans? This was the best kind of problem to have.
Old Jul 24, 2019 | 03:57 PM
colo63sw's Avatar
colo63sw
Agree. I'll take a 'push a button to solve' problem any day. I guess I need to do more driving with my reading glasses on.
To Speedometer too fast
