C4 Heater Core - Can I Bypass it??
My Heater Core has started to leak on my 87 Coupe. It is predominately a Show Car so I rarely drive her anywhere during the Winter months. She is usually garaged , battery rendered and Covered.
I'm getting mixed responses....replacing the heater core vs Bypassing it altogether. Replacing it is a Big P.I.A.....over the course of 17 years of ownership I've rarely if ever used the heat...So I've been told that Bypassing is a much easier and cheaper option.
Then I'm being told that the Heater Core is a necessary integral piece of equipment that CANNOT Be bypassed.
So What's the truth?? I'm certain that someone out there has been in my shoes. Thanks
Chewch87 (08-07-2019)
I'm not into shows and don't really go to them so I am not sure what their standards are. You need to know that up front that you could be dinged for bypassing it or not. If the goal is 100% originality, fix it correctly. IF it isn't, that depends on you. I drive my car when it is cold and I like the defrost feature. Both of which can't happen without the heater core. So for me, it cannot be bypassed. For me, AC is "make or break" so either you sell me a car that is fixed or I have to figure in the cost to repair everything in the system plus labor. So for me, AC cannot be bypassed either.
I guess it depends on you. I would rig a bypass for now and fix it later but that's me. IIRC, the hoses are different sized so maybe you need to stretch one or get hardware to bypass it from the hardware store. I would think that you can just loop it.
https://www.ebay.com/i/303103646719?...xoCRPkQAvD_BwE
She has to go in the shop for a Transmission pan gasket leak so I'm going to go the bypass route now and perhaps later have the heater core replaced.
I was just concerned that it was somehow tied into the Air Conditioning or may cause an overheating reaction.
Thanks for your input & the Ebay link as well!!
On mine it was just a hose bent between the two ports. Worked fine. The heater is installed with Tees anyway iirc so it isn't obstructing a direct cooling path.
As someone who replaced the heater core, just fix it. You will get absolutely brutalized in value with the heater core bypassed. It isnt THAT bad. Its about half as bad as people say. More uncomfortable than hard.
Or if youre taking it into the shop, have them fix it. It is likely under a grand for a shop to fix.
If you insist on bypassing it, a simple adapter will let you connect the two hoses.
My heater core was leaking on my 85 and I decided to replace it myself. It was a very difficult job. Some screws were almost impossible to get off and impossible to get back on. It’s almost like they built the car around the HC. I’m glad I fixed it as I prefer to keep everything 100% stock and functioning. If you do decide to fix it, just plan on a 12+ hour job maybe less if your are more skilled than me.
Mine is bypassed as for now. The pic was the first one I did using pvc until I went to get some brass fittings as the pvc would have not held up. I used some brass fittings to connect the hoses together. Put a zip tie to a brace so they are held so they can't flop around. I plan on replacing the heater core already bought a new one. But to hot here now to do that job. I will wait till around November or so then maybe get to use the heat January or February.
Mind you mine has been converted to RHD not sure how it affects the job
I'd replace it. The most expensive one on RockAuto is $36.00
https://www.rockauto.com/en/catalog/...ater+core,6864
One thing for sure about my 87 and I assume other C4's....the AC SURE IS CO CO CO COLLLLD!!!! Most times I keep it on low and turn the vents away and I tell you what....puts the AC temp in my $60k Caddy to shame.
Guess what.....Its a C4....although I LOVE MY VETTE...realistically.....monetary wise they are worth ****....So the motivation Of losing its "value" by not having a functional heater (Which I NEVER HAVE USED IN 17 YEARS) as opposed to spending $1,000.... to replace it..... ALWAYS having the option to replace it later.... I'm going the Bypass route!
Yes....I would rather take that $1000 and put on a new Corsa Exhaust!! I'm going the bypass route....I can always have it done later....but after 17 years of ownership.....I don't think I've ever used the Heater!!! NOT a cost effective repair.... the overall and future value of the Vette makes it not worth the cost.
Not mine. It is cool with a new condenser, compressor, etc. Cool, yes. Cold, as in fast gp 68,no.
Chewch87 (08-12-2019)
The $1000 repair vs the current and future value of a C4 makes it an unnecessary repair that can be done later on if Needed....
