1986 corvette
Old Aug 11, 2019 | 01:00 PM
Ranger150's Avatar
Ranger150
1st Gear
Default 1986 corvette
So I purchased a 1986 corvette as a project car to know more about cars but it looks like it’s a v6? Idk I only see three exhaust pipes on the headers on each side and I’m not sure if that’s normal or not since when I did my research it doesn’t seem like there’s such thing as a v6 corvette. Please help I am very confused.
Old Aug 11, 2019 | 01:08 PM
JTSK's Avatar
JTSK
There wasn't. Can you post up a picture?
Old Aug 11, 2019 | 01:11 PM
Joe K's Avatar
Joe K
2022 C4 of the Year Finalist - Unmodified
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (appearance mods) 2019
The center exhaust ports are side by side thus it looks to be one pipe. Count the spark plug wires should be 8.
Congratulations on your new car.
Joe K
Old Aug 11, 2019 | 03:58 PM
Y-bodluvr's Avatar
Y-bodluvr
Hoo boy
Old Aug 11, 2019 | 07:11 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
try counting plug wires on each side instead
Old Aug 11, 2019 | 09:37 PM
Hot Rod Roy's Avatar
Hot Rod Roy
He's probably looking at the exhaust manifold heat shield. Gotta start learning somewhere!
Mr. Ranger, Your engine is called an L-98, and is distinctive because of the eight large intake manifold tubes on the top of the engine. Welcome to the Forum! Enjoy that nice 'vette! We like pictures!
The best way to learn about your new Corvette is to purchase a copy of the Factory Shop Manual (FSM) for your '86. They're a little expensive, but you'll find they are worth their weight in gold! Don't bother with the Haynes or Chiltons manuals. They are too generic and can lead you astray.
Old Aug 11, 2019 | 10:28 PM
jv9999's Avatar
jv9999
You're going to have some fun! Congrats!
Old Aug 12, 2019 | 02:27 AM
ghoastrider1's Avatar
ghoastrider1
welcome to the site and the Corvette world. Dont forget the wave.
Old Aug 12, 2019 | 03:36 AM
hcbph's Avatar
hcbph
Yes there is a shield over the exhaust manifolds that covers the exhaust manifold. Easiest as suggested earlier is if in doubt, count the spark plugs. Yours may or may not look exactly like this one. I've got the aluminum heads, which you can tell by the hold downs centered on the valve covers, while the cast iron heads had perimeter bolts. Early coupes had cast iron, later had aluminum ones while all the convertibles had aluminum heads. Hope that helps.
Old Aug 12, 2019 | 08:24 AM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Hey hcbph, ware did you get those plug wire heat cover thingies. P.S, sorry for the hijack.
Old Aug 12, 2019 | 09:39 AM
hcbph's Avatar
hcbph
Those came off Ebay. I had to cut the metal rings out of them so they'd slide only the plug wires - they're designed to slide onto new wires as they're being assembled.
Old Aug 13, 2019 | 03:23 PM
kael's Avatar
kael
The FSM can be found in digital format (PDF) for $30 in various places, such as https://www.corvettecentral.com/acce...-cd-rom-114031
Careful on assuming the heads are iron or aluminum, '86 was the split year, iron or aluminum were put in these, aluminum in the later builds.
Finally, Welcome to the C4 Corvette!
Old Aug 13, 2019 | 05:40 PM
mazdaverx7's Avatar
mazdaverx7
Welcome! As other have stated, you may be misinterpreting the exhaust layout due to the arrangement of the heat shield. Would love to see pictures of your new 86! I have an 86 as well!
Old Aug 14, 2019 | 05:51 PM
86C4Z51's Avatar
86C4Z51
Tis a good year Corvette, but it came with a V8, my friend.
To 1986 corvette
