1989 Project Car
Can’t hurt to ask her, make sure to tell her you want to restore it. It might help her to know that car was not going for parts.
Let us know what happens !
I would go for it in a heartbeat if you can come to a fair agreement (free or not over $1500). In the end you will have a great driver.
Since you're here asking I'm assuming this would be your first effort at saving a neglected car. That's ok, we all start somewhere. I'm on my fourth effort to bring back a neglected car, a '73 El Camino. But back to your question, this car is going to require a MINIMUM $5000 above what you pay for the car to get it to a point where you can drive it on a regular basis. You should budget for the following items.
You should check with RockAuto, Zip Corvette, Corvette Central, Eckler's Corvette, Mid America Motorworks and others for parts pricing.
New tires, the ones on that car are toast, drive around the block only if you're brave.
Fuel sender, fuel pump, fuel filter
Replace all rubber hoses, radiator, heater, coolant bypass
New fuel injectors from FIC (Fuel Injector Connection)
Plenum gaskets, throttle body gaskets, etc (req'd to change injectors)
Brake rotors and pads, those rotors will be too rusted to save and the pads are likely bonded to the rotor so the wheels won't turn
One or more wheel hubs
New shocks (possibly)
New carpet
Possibly some type of seat cover, depending on if the leather can be saved or if just cracks and crumbles
Digital dash (cool feature I think) may need to be rebuilt to function
Battery
All new fluids
You get the idea, lots more than clean up and drive here for this car. Paint. The paint MIGHT clean up fairly well, but plan to spend serious time hand buffing this car with polishing compounds. Do some research on this, there is a ton of info on working on paint. But this car I think will require all hand work unless you are quite experienced with a buffer as the paint is likely very thin on this car. If hand polishing doesn't sound like fun (it isn't) then you have to budget for a professional to take a shot at it to hopefully get a result that is good enough to not require a repaint.
In my opinion it would be worth the effort only if the '89 year really trips your trigger and you plan on keeping the car several years and be prepared to loose money when the time comes to let it go. Me? I'd take it on because I'm a car nut, like early C4s, and never go into it thinking I'm getting anything out of it except enjoyment. The money is wasted. So I try to enjoy the experience of the project.
! get car for 1000 or under.
2 vacuume the car
3 Change oil/ rinse antifreeze with water for now.
3 New Battery
4 Wash car
5 Clean all connectors you can with electric cleaner or at least inspect
6 Edit drain the old gas and put a gallon of new. It is actually easy to inspect the tank on these.
You can get lucky or just sell it again if you have to.
So, I took some more pictures today, unfortunately she wasn't home to talk some more. I feel like this is not as bad as it looks. Yes, the obvious will have to done like tires, battery, fluids, fuel, and probably the pads are fused to the rotors as mentioned, at least it looks like they are but i'm hoping some penetrating fluid would free them? Oh well, here are more pics:
