determined to fix this engine problem 1994 corvette
im old old school points, condenser, dwell meter
and timing light i had a 69 big block roadster that could be tuned in an hour
then and now
Coincidentally I am presently in Sarasota Florida working a house with my son. Sounds like your 94 had the same problems as mine? After several months of diagnosis, replacing allot of parts and taking allot of heat from this forum I decided to send out my PCM for rebuild. All indicators seem to point to the PCM as the problem. It was sent to Module Experts in Jacksonville Florida. They called me this week to tell me my PCM could not be rebuilt and I was right with my diagnosis. I felt pretty good at that point. The only problem I had with that was they offered very quickly to send me a rebuilt one for over a thousand dollars. When I said no way my salesman (Mark) became very quick with me. They did send it back and I received it yesterday but there was no paperwork with it. No diagnosis and no receipt of charges. I had a feeling I was being scammed for the high cost of another unit! However I sent an e-mail to
the company late last night and they responded quickly. I should get my paperwork and a receipt today. I feel a bit better..... but how do I know my unit is truly bad and can not be rebuilt? Should I get a second opinion? I have two PCM presently, the original and a rebuilt one I purchased from O'Riely auto parts. The rebuilt one does not work in the car, I already tried several times. It started the first but did not run any better, after that the car would not even start! So now here I am, what direction do I go?
My thoughts are to send both units out to another repair facility that flashes the PCM. Have them confirm the diagnosis first and if it is truly bad flash my rebuilt one to me VIN#. This car is a base coupe but is in great original condition. I am determined to fix it (within a reasonable cost). Thank you for your response it is appreciated!
https://www.zip-corvette.com/84-96-c...dules-ecm.html
pinellas park r and b auto service. 5 star rated across the board. had a hand full of vettes there when i arrived. jump on line for the phone number or you can call iggy @ 786 356 8415 . hes in miami and has been selling used parts for years. hes a straight shooter if it doesn't work he'll take it back.. i got a bose main amp from him that was ng, called him he said send it back i'll refund your card, and he did. i think when i get mine squared away i'll sell the car and move to an early c7. something that can b hooked up to a modern scanner and diagnosed instantly. i put a ton of dough in mine to get it where it is but i want to drive it not tinker with it.
new top and weather stripping,fixed the bose gold radio. i'm a purist 'm not about to devalue my car with a non matching radio.
installed new seat bladders, oem power antenna, brandy new OEM door panels (got em online 500 a piece) the after markets suck and are more dough.
did the opti,coil,water pump, plugs, wires and mufflers. new rubber, front brakes and rotors.
the car is near perfect until 3 weeks ago when all this started. have u jumped the ob port with a paper clip to check for codes? at the onset mine pulled h22 h53 and h64. i replaced my tps and o2 sensors
and it made a huge difference. i pulled a couple of plugs and decided to replace them all 8 were carbon fouled
ive had 11 vettes, 7 of them c4's 3 of which i bought new in 84,85 and 86. never had issues with any of them. changed the oil and drove em.
if u know any one interested in a true 40th anniversary it can b had for 15 grand plus whatever this repair cost. i just hit 70 so i wanna play not work. i plan on poppin the clutch to my grave
forgot to mention new cluch kit
That being said.
You fckers are eating major crow on this one
Y'all treated this man like a noob and he was right, all along.
apparantly so.
heres a couple of my restos from 80's
and a super car from the early 90s of which i had many. i'd love to c u under the hood of that v12. you'd be dumbfounded
not like we dont know what time it is. our era was points coil condenser and dwell meter
According to the diagnosis from Module Experts I have a shorted CPU (central processing unit) I had to research what that meant, in the PCM that can not be repaired. I purchased a rebuilt unit from O'Rielly auto parts for under 100 dollars. The unit needs to be programmed to my Vin# to work. I have a choice to send it out to have it benched flashed or take the car to my local GM dealer. The cost is about the same. If I can get the car running I think I will take it to GM?
I can take the abuse on this web site. For heavens sake, I am a retired Coach and PE teacher working on vettes! This forum has helped me so many times in the past. I do however have a FSM for sale that I did not want to buy!!!!!
Rich Harris
Basically, at this point the OP doesn't know any more about the problem than when he started. Nobody here has said it definitely isn't the PCM. We're just saying that's less likely than any one of a number sensors or wiring faults. It doesn't sound like a typical PCM-gone-bad set of symptoms. Tom pointed out that he has some DTCs, and a couple of us suggested data-logging to see what the PCM sees when it enters open-loop operation. No info to date contradicts that advice. Again, that doesn't mean that we think the PCM can't be the problem - just that it's not the most likely suspect.
The OP has already probably spent at least $300 for another (non-flashed) PCM and for "diagnostic services" from the fishy shop in FL, maybe more. Depending on how much it costs, at this point it may actually make sense to get that O'Reilly PCM flashed for his car and to try it out. For example, if it's only $100 to get it programmed correctly, that's worth maybe two hours of the OP's own time or only one hour of a shop's time. I have no idea how much people charge for a bench flash, but the dealership is probably going to be prohibitive if they even still have the equipment to do it on a 94.
To the OP: with the original PCM in the car, do the fans run constantly, regardless of coolant temp or a/c setting? If so, that is a sign that the PCM is faulty.
I bought this corvette as a learning experience, I have achieved my goal! I learned not to do it again!!!! Love my C5 but looking at the C8!
Thanks all,
OP
I received the bad PCM back from module experts. The diagnosis is a shorted (CPU) and can not be repaired. I put the unit back into the car and it acts the same. By disconnecting the map sensor it forces the car into open loop. The car runs great! I have the rebuilt PCM from O'Rielly auto parts. It needs to be flashed, programmed to my car. Since the car runs so well in open loop I am going to take it to my local dealer for programming. I was quoted 159 for this service? I will be making an appointment tomorrow.
TO BE CONTINUED!
in power, ride and comfort. the car is in really
nice shape w/94000 pampered miles owned by the same guy fo 13 years. new top, magna flow ehaust, ac compressor and water pump. so after
owning 7 c4s i have entered a new world
plus its an automatic. i love sticks but in florida with all the traffic too much shifting
nice ride for 11 grand. i keep waitin for the cops to come arrest me for car theft 😁💪
Zip corvette parts sells them . i think you provide your vin and they set it up might b worth investigating. not mention your opti spark acting up
or o2 sensors causing poor idle and misfiring.(so i've read) i swapped mine with new ones along with the throttle position sensor all a waste of time and $.
just some more food for thought. check out your plugs see if they are carbon fouled. i changed mine
still running poorly. good luck if all else fails r&b auto service in pinellas park ( vettes and caddies only) if ur still in sarasota
I will keep all posted on the repair. Thank you!
