Diagnostic tool
Old Sep 7, 2019 | 11:32 PM
Bigmike4098's Avatar
Bigmike4098
Default Diagnostic tool
Hey guys need some help. I went and got a diagnostic tool bosch 1300 obd1 and 2 reader. I can't get it to connect to the car ecm. I know the tool works it works on my 2001 celica and my 90 escort. But it tells me to turn key on when I use it on the vett. (Yes I'm turning the key on) could my ecm be bad. And I have tried the diagnostic mode on the ecm it comes up with code 12 and that's all. So I wanted to use the tool to see my live feed data and make sure it's all working right.
Old Sep 8, 2019 | 04:07 AM
stabac's Avatar
stabac
I just went through the process and learned a little about the diagnosis. Code 12 means it is in the diagnosis mode. Maybe you don't have any error codes in your system to display. Any previous codes remain in memory until you disconnect the battery or clear them.
Old Sep 8, 2019 | 09:22 AM
Bigmike4098
Right but my car is not running right. That's why I need the tool to see what sensors are doing what.
Old Sep 8, 2019 | 09:35 AM
stabac's Avatar
stabac
I believe the system has to detect an error at which point the "Check Engine" light will come on. Then you can use the tools to see what the code indicates.
To Diagnostic tool
