C4 issue
Old Sep 8, 2019 | 12:22 PM
Billyg769's Avatar
Billyg769
5th Gear
Default C4 issue
My name is Billy Grafius and I am a new member needing some advice solving a problem with my 1995 corvette coupe 5.7L. Car is in excellent shape with about 65,000 miles. Car runs great down the road but upon stopping, like at stop sign or light engine begins to shake and seems like it’s about to cut off but doesn’t. Then upon acceleration acts like it’s not getting gas and after a few seconds begins to perform as should. Have it in the shop now and diagnostic test showed no problems and fuel pressure test showed no problems. After speaking with one of my vette buddies and mechanic suggested changing out optispark and possibly water pump if original since it had to be pulled anyhow. Didn’t guarantee this may solve problem but since optispark is the weakest link on this model was a good start. If anyone has had similar problem and has any input it would be appreciated. Thanks in advance.
Old Sep 8, 2019 | 01:39 PM
marines's Avatar
marines
Speaking just for me, I had similar experience and it was from a leaky water pump which then affected the opti-spark. Replaced both and no problem since.
Old Sep 8, 2019 | 01:52 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
take it to a shop that can trouble shoot without throwing parts at it. it will save you a ton of money in the long run. for starters is the check engine light one?
Old Sep 10, 2019 | 11:26 PM
TractionControlOff's Avatar
TractionControlOff
I also experienced a rough idle prior to replacing the water pump and opti but I wouldn't blindly replace that without properly diagnosing. That's a big job, relatively speaking.
Old Sep 11, 2019 | 01:32 AM
383vett's Avatar
383vett
I always start with plugs and wires.
To C4 issue
