1984 Corvette Coupe
Old Sep 29, 2019 | 12:07 PM
nryans34express's Avatar
nryans34express
7th Gear
Default 1984 Corvette Coupe
New to the forums. I have a 1984 Corvette Coupe I brought 6 months ago. Getting cooler now and this morning I turned on my heater and it's blowing cold air. I set the blower to high. The panel I set to heater, and the top button to economy. I tried everything possible. The temperature of coolant was 200. Should be hot enough. Is there a termstat in the 1984. Any help is appreciated.
David
Old Sep 29, 2019 | 02:46 PM
ls777z's Avatar
ls777z
There is a thermostat but you should at least get warm air. Are you sure the heater core hasn't been bypassed because of it leaking?
Old Sep 29, 2019 | 03:22 PM
nryans34express
7th Gear
I don't think so. I'll have to check it out. I don't see anything leaking on the ground thought.
Old Sep 29, 2019 | 04:47 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Also check your coolant level, if low that could cause a no heat condition.
Old Sep 29, 2019 | 06:25 PM
Z51JEFF's Avatar
Z51JEFF
Check they the valve that controls water through the heater core is working. This valve is controlled by vacuum and is inline with the heater hoses.
Old Sep 29, 2019 | 06:44 PM
nryans34express
7th Gear
Thanks I will do that
To 1984 Corvette Coupe
