Check engine light
Old Oct 16, 2019 | 12:10 PM
Klgrayson's Avatar
Klgrayson
Default Check engine light
Check engine light is on in my 1984 Corvette how do you go about obtaining the codes every garage I have went to no one has the equipment the sad thing is the car is running so smooth and I am just making the Sumption that the oxygen sensor is bad Would like some input before I buy the sensor also I have a new gas cap hope to hear from someone soon
Old Oct 16, 2019 | 01:55 PM
Kevova's Avatar
Kevova
https://tech.corvettecentral.com/201...trouble-codes/
You should consider getting repair manual; factory service manuals are preferred. Also OBD1 scanner with correct cartridge for 82-84 CFI ( Crossfire Fuel Injection). EBay is a good place to look for both. Digital Volt Ohm Meter (DVOM) to diagnose.
Old Oct 17, 2019 | 12:52 AM
Hot Rod Roy's Avatar
Hot Rod Roy
I have another name for my OBD 1 scanner. I call it a "paper clip".
1. Paper clip jumper between ALCL pins A & B (upper right). ALCL connector is at bottom of dash, just to the right of your steering column.
2. Key On Engine Off.
3. Check Engine light will flash "12" code three times. ( 1 - 2 - - 1 - 2 - - 1 - 2)
4. Error codes will follow, with the same format. Count the flashes.
5. Report back to us.
I think it's been recommended before, but yes, you need an FSM.
Old Oct 17, 2019 | 09:25 PM
stabac's Avatar
stabac
To Check engine light
