I just bought an Intellitronix dash for my 87 and some of the wiring they are saying I should use just doesnt add up to what my wiring supplement says.
For instance they say to run speedometer white wire from the unit to my C15 pin on the cluster connection and then loop the D11 and D3 pins which they are saying are Pink with black stripe..
But my manual says C15 is a black ground, D11 is Speed input Yellow and D3 is Ground, Black..
I'm not getting much help from their support staff either...
Anyone on the form Installed one of these units on their C4's?
Installing an Intellitronix AP2003 now. Can’t find yellow with red stripe for fuel pump. Also unsure of Speedo wires. Anybody get one of these to work properly.
From the way you're describing it, seems to me that it means the white wire FROM THE UNIT connects to the c15 pin on the car. I have an '88 and my c15 wire is Purple (go figure). Not owning one of these, I'm just going by what you're saying the instructions are. Seems like they're not very clear.
My C15 is Purple also. I grabbed the C16 It is the Purple with the black stripe. I have not driven the car yet. So I dont know if the Speedo works.
