Weird brake noises
Old Oct 23, 2019 | 10:42 AM
DarkWizard69's Avatar
DarkWizard69
3rd Gear
Default Weird brake noises
Hi, when I push in the brake pedal it sounds like a creaky wooden floor. I have plenty of brake pad left and the brake fluid is a little over halfway between min and max. What could be causing this issue?
Old Oct 24, 2019 | 07:12 AM
Clyde_84_c4's Avatar
Clyde_84_c4
Noise come from the wheels or from inside the car?
From the wheels I would suspect glazed brake pads.
Old Oct 24, 2019 | 02:21 PM
DarkWizard69
3rd Gear
I believe it is coming from the rear wheels. Occasionally my brake lights will also get stuck and sometimes I have to pull the exterior lights fuse.
Old Oct 25, 2019 | 04:04 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Check your brakes hoses, if rubber they may be getting too soft. Might be air in the brakes lines, maybe time to flush the brake fluid. What color is the fluid?
To Weird brake noises
