Battery Tender
Old Oct 24, 2019 | 01:31 PM
marines's Avatar
marines
Default Battery Tender
Thank you for looking at my post and perhaps you can answer my question. I have a base 1993 coupe that may or may not have an electrical drainage problem, although not severe. When I first start up the reading is 14.7 but after a few miles it degrades to about 14.1. I think this is normal. My question regards my old (instructions are long gone battery tender. Do y'all leave it plugged in whenever you are not using the car? Constantly? I had one short out and burned the wires and that is why I am goosey. Thank you for any information you can share.
Old Oct 24, 2019 | 02:36 PM
car addict's Avatar
car addict
I use mine (battery tender) only in winter when car is parked for more than a week. Otherwise nearly never use it. When I do use it, I just leave it plugged in. Claiming no expertise. Don't give it a lot of thought.
Old Oct 24, 2019 | 08:00 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
As long as it is one of the "smart" tenders, it is safe to leave them plugged in all the time.
I've had a Battery Tender Jr. connected to my '96 for 4 or 5 months at a time over the last several years.
Never had any issues with it.
Old Oct 24, 2019 | 08:59 PM
SJW's Avatar
SJW
I've used Schumacher brand tenders for years, leaving them connected all winter long, and whenever the vehicles are unused for a week or more. I wired a cigarette lighter plug to my tender, and just plug the cord into the lighter socket to feed the battery. I have about 12 feet of wire between the tender and the lighter plug, so the tender hangs on the wall of my garage, wires go up and over (hanging over a hook that's dangling from the garage door track overhead), and through the open window of the car. Easy peasy, no fuss no muss, no cords to trip over, and connects/disconnects in a few seconds.
The lighter circuit in the car is fused, and for additional assurance, I used a lighter plug that has its own internal fuse holder. My tender puts out 1.5 amps, so I installed a 3 amp fuse in the lighter plug. That fuse will blow before anywhere near enough current can pass through to damage anything in the car.
I've never had a problem with this arrangement. Works great for me, and I've wired up several tenders in the same way for friends and family.
Live well,
SJW
Old Oct 25, 2019 | 05:30 AM
Paul Workman's Avatar
Paul Workman
with both. I use the Battery Tender brand tender which is a "smart charger" designed (like some other smart chargers) to be left connected anytime the (car) sits.
I leave the tender(s) connected whenever the Vettes sit idle (driven mostly on weekends a couple times a month.)
Modern electronic so-called "TENDERS" differ from simple (old) trickle chargers in that they monitor the voltage and shut off automatically when the battery teaches full charge. This keeps from boiling the battery dry if left on like the old fashioned simple (dumb) chargers used to. And, "smart chargers" are programmed to pulse the battery with short bursts to prevent lead sulfate from building up as is normally the case when a lead acid battery sits idle (primarily in warm weather - not so much a problem when temps get below freezing.)
"Thus endith the lesson!" (Sean Connery in the movie "Untouchables").
Old Oct 25, 2019 | 09:34 PM
rusty76's Avatar
rusty76
I've been using battery tenders, from various manufacturers, for many years to keep my motorcycle batteries charged through the winter. I've never had a problem, though I must throw in that I take the batteries out of the bikes and keep them in my basement. I leave them all plugged in all the time.
BTW, I suspected a parasitic drain on my '93 as well but, after putting my digital VM on it numerous times, never confirmed it. I DID notice that if I checked the voltage on the digital voltmeter in the dash before I started the car (ignition on but not started) voltage always reads low and the longer between starts the lower the voltage but the car always starts with not problem. I suspect something about the built in digital voltmeter is returning incorrect voltage reading with the key on.
Old Oct 26, 2019 | 07:58 PM
hcbph's Avatar
hcbph
I don't user a battery tender, have not needed one so far. Now I do have a heavy duty battery cutoff in the car and if I'm not using the car for a long time or it's in winter storage I just flip the switch and disconnect the battery. One side benefit to a battery cutoff is there's virtually zero chance of having an electrical issue without a connected battery in the car. During the winter I do start the car and set it up or operating temp and if the alley is clean will drive the car up and down the alley a little.
Some swear by a battery tender, some swear at them. It's your choice.
Old Oct 27, 2019 | 01:34 PM
Paul Workman
To determine parasitic draw, realize you have to set the VOM up to read Amperes. (You never mentioned that, so I have to wonder if you knew that?). Normal C4 current draw is ~25-30 mA (.025 to .03A), when one of the battery cables is disconnected (either will work, but the negative is more accessible) between the disconnected battery cable and the battery post (allowing for an initial surge to pass).
A consistent draw exceeding 50 mA is excessive. You can cut to the chase by reconnecting the battery cable to the battery, and then testing each of the fused links (you will have to remove the GILL PANEL behind the battery to access the fused links. (Refer to the FSM of details!)
Once you have identified the particular circuit with the excessive draw, then it is a process of systematically testing and eliminating the components associated with that jused link.
Good luck Sorry for the short shrift just now...
Old Oct 27, 2019 | 04:21 PM
rusty76's Avatar
rusty76
I've tested just as you describe, never got above 30mA as a reading in several tests across a few weeks. I made it easier to do the tests by putting a disconnect on the negative terminal so it's quick to do a test. Also had the battery load tested to insure it was good.
Old Oct 27, 2019 | 11:14 PM
Yukon Corleone's Avatar
Yukon Corleone
C4 of Year Finalist (stock) 2019
I have been using the Deltran Battery Tender and CTEK MXS 5.0 on both of my fun cars. I did have problem with the Corvette battery and couldn’t figure out why the battery died. It was gone and had to be replaced. I did a search here and found a thread where someone ask if something was left on. I check and found out that a light was left on a visor vanity light mirror. I turned it off, replaced the battery and all was good lesson learned, now I won’t let a two year girl play in the car, she likes to look at herself in the mirror
Here is a video I made showing how to attach a CTEK or Battery Tender for someone on the Focus RS Forum:
Old Oct 28, 2019 | 12:43 AM
rusty76's Avatar
rusty76
I thought I had left my vanity light on as well but I determined that, at least on my '93, the vanity light is only live when the key is in the on position.
Old Oct 28, 2019 | 08:30 AM
bosshog8's Avatar
bosshog8
I have been using "battery tenders" (on average 10 or so at any given time) for well over a decade on a consistent basis (plugged in the entire time the car, motorcycle, RV is parked) and have never had an issue. The only trouble I've had is with the "Battery Tender" brand. I don't use them any more as they fail too often. I imagine when the tenders were actual transformers inside the "shorting" situation you mentioned was possible but pretty much none of the individual tenders have transformers inside any more. They are all just circuitry and when they fail they just don't do anything. They generate no heat like the old transformers did.
To Battery Tender
