dash cluster
Old Nov 14, 2002 | 06:59 PM
jvesalga's Avatar
jvesalga
Default dash cluster
Hi All,
I have a cluster question. Mine is having some difficulties and has the usual symptoms of going off and on when hitting a bump in the road. Has anyone every experienced this and found the fix to be only reseating the cables like reseating the boards in a PC. Just wondering if this always means the cluster itself needs repair.
thanks
joe
Old Nov 14, 2002 | 07:38 PM
GoodbyeGirl's Avatar
GoodbyeGirl
Cruise-In III Veteran
Default Re: dash cluster (jvesalga)
You might want to post this in the Tech/Performance section. You'll probably get more responses :)
Old Nov 14, 2002 | 10:20 PM
vader86's Avatar
vader86
Its caused by a loose connection inside the dash unit usually. You must remove the unit entirely and resolder the connections inside, and the problem should disappear.
And you may as well replace the 4 bulbs in the unit while youre in there, they are Sylvania 882s.
Old Nov 14, 2002 | 11:06 PM
jfb's Avatar
jfb
There are two circuit boards in your cluster and they plug together with a single row of pins on the forward board into a socket on the rear board. The pin closest to the center of the board carries the lamp current and this current flowing through an age relaxed spring on the socket causes heat to the point where the pin unsolders itself and causes the intermittent condition.
Resoldering the pin will not cure the problem, replacement of the socket is required, or, a permenant fix which I did to my 87 dash is to solder a short insulated small piece of hookup wire from the rear board pin to the front board socket.
Old Nov 14, 2002 | 11:49 PM
RUSS105's Avatar
RUSS105
Default Re: dash cluster (jfb)
I have the exact same problem. Is it that simple? I was contemplating wheather I should send it to a repair place or buy a new one, but since we have someone who's done this before, I will take the opportunity to give it a shot myself.
Is there any particular soldering wire needed and where would you buy the socket. I'm assuming in a radio shack. Please let me know. I will attempt to do this in the next few days. I hope you don't mind if I send pics of stuff to get me by. :yesnod:
Old Nov 15, 2002 | 11:14 AM
jmh63's Avatar
jmh63
You might want to check out this link:
http://www.corvettemagazine.com/1999...ash/dashp1.asp
Old Nov 15, 2002 | 12:34 PM
chucks00's Avatar
chucks00
Cruise-In III & VI Veteran
I agree with jfb. My 87 had the same problem and resolding the pin lasted about 6 months before I had to take it apart again. For some good pictures and info on how to take the cluster apart you can also check out this site. http://www.batee.com/corvette/
Old Nov 18, 2002 | 02:18 PM
jvesalga's Avatar
jvesalga
Default Re: dash cluster (Chucks87)
thanks all
joe
To dash cluster
