thanks for the chart. I see the LT4 weighs about 200lbs more. Compression ratio is .5 higher and peak torque happens 500rpm higher and I wonder how much hp it makes at 5000 rpm, I wonder if less that LT1. Peak horsepower is greater at 330 but at almost 1000 rpm higher for only 30hp gain. Roller rockers, stronger timing gears, both run on premium gas 93 so thats no different. Is it really worth it Im wondering and it was only made the one year. Are there parts that would be impossible to find whereas the LT1 is everywhere? What do you all advise?
You've been advised to go drive one of each. Your posts read like you're wanting someone to tell you there's no benefit to the lt4 over lt1 but that simply isn't true. HP is a poor indicator of engine performance and 2 vehicles with identical hp could have very different behavior
There is no way the lt4 weighs 200 pounds more. Yes, I see the link says so. But how that is logical, is beyond me.
Bingo. The 2 different transmissions actually weigh close to each other, with the 4L60E actually weighing more once it is filled with fluid.
There is no component that differs between the 2 that can add 200 lbs.
Probably only the knock sensor, which is unique to the LT4, otherwise, it is just a small block chevy for the most part. Take the rockers, while you might not be able to find an exact OEM replacement one, there are plenty of roller rockers that are more than adequate replacements.
Yeah, the goofey chart has been around for years. It seems that they include the weight of the transmission and the dual-mass flywheel (which alone is 40 lbs) for the LT4, but they weighed the LT1 alone. Or something. The reality is that either engine weighs around 520-530 lbs by itself. I don't know where those weights came from. If anything, the LT4 is a few ounces lighter because it doesn't have an EGR system.
Well...yeah, that's how power is generally made from the same displacement. And power is the sole determinant of which car is faster in a straight line. Period. The LT4 has 10% more power than the LT1, and a wider rpm range as well. If they had equipped the car with a 3.73 rear gear (so that redlines occur at about the same road speed), you'd feel that extra power directly. As it is, the car is longer-legged than an LT1 since it can hold any gear to a higher road speed and keep accelerating in that lower gear after the LT1 car had to shift. You'll drive right by an LT1 car. This is not just on-paper power. It's meaningful.
The LT4 also has higher compression to make up for the slightly longer intake duration and overlap, so it won't lose anything in the midrange. At any rpm that matters at all, it's either equal to or more powerful than the LT1. You have more flexibility of when/where to shift it. The one stock LT4 C4 I've driven was just lovely to drive on the street or in competition. It's just a better engine all around.
Reworked? Haha. If you rework the LS like they did the LT4’s they will easily blow that time away. Just one turbo on an LS engine would destroy that time slip. LS engines are still king when it comes to horsepower. My 98 Z will stomp my two low mileage C4 cars. All three are completely stock. My wife’s GMC Yukon Denali XL comes close to beating my C4 cars. The 6.2 LS engine is a beast of a motor. I am a former racer so I know how to drive a car and all we do is a straight line shot and she can get het beast moving. Crazy how awesome the LS platform is. LT1/4 are good engines but an LS they are not.
Reworked meaning SLP took the engines apart and did a mild blueprinting to make sure there weren't any duds. That's long way from adding turbos. Changing heads and intakes. The 97 -98 LS1 wasn't anything special, especially with an automatic. The later LS6 showed it's potential in the future. You should expect a LS to out perform an engine that was designed in the fifties. The LS became the darling with lots of support. The gen 2 has always been the redheaded stepchild that got scraps. With limited support through the 5 year run. The unreliability of the 92-93 Optispark set the stage. Stick with what works the Gen 1 sbc and a carb.
You're usually more accurate than this...OP was talking about peak engine horsepower which isn't the sole determinant of which car is faster in a straight line. I'm actually not disagreeing with your statement since I know you were referring to "tractive force per unit time" (isn't that what you've called it in the past?) but your reply may be misleading to some
Well, true that over any given distance it's the car that can apply the most average power over the distance. However, the LT4 can most definitely do that - it makes more power over the top, say, 2000rpm of its rpm range than the LT1 does over the top 2000rpm range. That is to say, there is no road speed where an LT4 Corvette cannot put more power to the wheels than an LT1-equipped Corvette. Ergo, at any road speed you care to reference, the LT4 can accelerate quicker.
So actually I was referring to average power during a run through the gears, not just peak power. It is useful to point this out more clearly, though. The OP needs to know that the LT4 isn't just more powerful at one specific rpm. I had alluded to that, but didn't explicitly say it.
I highly suggest driving both LT1 and LT4 cars. The power isn't just when hammering it... the power the LT4 makes can be felt driving the car to the end of the road just cruising. It's impossible to explain without just feeling it for yourself. The LT4 feels like the L98 down low... where all the torque makes it a fun daily driver / stoplight to stoplight car without having the massive falloff up top... they just want to keep revving to the moon, and they do so better than the LT1.
ultimately this is what I wanted to know. Thank you vette. Looking at the specs I was getting the impression that it was a high revving engine that was better for racing but not as good down low as the LT1 and that to really see any positive difference I would have to go over 5000 rpms which is not how I typically drive around town. Im back on the LT4 wagon now. This is why I ask questions in the forum, I like to hear real world experience and opinions from a variety of people.
Definitely not. This ain't no VTEC Honda or motorcycle engine we're talking about! It's a wonderful, uber-flexible engine that is very happy burbling around town or on a track. Hell, the CAGS skip-shift thing has you lugging 4th gear from 10mph at 500rpm or so unless you disable it. If this were a high-strung race-oriented engine that had to be revved to pull the car, GM could have never gotten away with that.
It blows my mind when the "1st to 4th" light comes on. Glad my PO disabled it!
what is this CAGS you speak of? Is it just a light to remind the driver to shift to 4th for fuel economy or does it actually do something in the transmission. ?
In stock form, it has a solenoid that forces a 1-4 shift unless you're over a certain percent throttle or certain mph. All LT1 and LT4 have it, I believe, as do C5s. It was a way to get an improved EPA fuel mileage rating. And it's horrific. Luckily, it is easy and cheap to bypass with a resistor kit (I think) or to disable it in the PCM if you have programming software (Jet DST software suite in the case of a 1996).
