Question about a Targa top
Old Dec 9, 2019 | 03:57 PM
cmw2212's Avatar
cmw2212
4th Gear
Default Question about a Targa top
Hi guys. I ended up getting a 1984 roller and I wanted to pull the targa top off to see if it could be repaired to use on my 86. When I look at the front there are 2 levers, one on each side. I can slide them left and right but it doesn't seem to make a difference. Can anyone point me in the right direction?
Old Dec 11, 2019 | 01:13 AM
RArline's Avatar
RArline
If it is a late 86 it may have the second generation top.
https://mirrockcorvette.com/c4-parts...tingvariations
Old Dec 11, 2019 | 09:13 AM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
The C4 targa tops never came with release slide levers, on any of the three designs. They were always mounted with torx screws you need the "special" tool to remove and install. Judging by your picture of the lever and the surrounding custom upholstery work on the header, it looks like your car has some customized gizmo installed that you will have to try to figure out (like you didn't know that already).
What happens if you slide that lever to either side and pull outward? It would seem there would be some kind of fail-safe designed into that set up to keep the top from being accidentally left in the unlocked position, and thus leaving yourself vulnerable to your own personal :flying top".
Old Dec 11, 2019 | 10:04 AM
s carter's Avatar
s carter
From the looks of it I wonder if what is being called a Latch Handle is really a Mount for a Sun Shade and the roof removal is the Normal Torx Long Bit
To Question about a Targa top
