C4 Headlight Problem - Please help!
Old Dec 12, 2019 | 10:30 AM
marjoy01's Avatar
marjoy01
3rd Gear
Default C4 Headlight Problem - Please help!
I can not retract the driver side headlight. I have tried to retract it manually but the gears simply do not engage. I believe that the assembly must be in the retracted or down position in order to remove the assembly for a rebuild. Can anyone please provide advice on how I can move the headlight to the retracted position without damaging anything. I sincerely appreciate any advice you can provide.
Old Dec 12, 2019 | 01:24 PM
3D-Aircrew's Avatar
3D-Aircrew
Welcome!
There is a **** on the bottom of the motor that if you rotate it it will retract the headlight manually. It's possible that the gears are bad and maybe this won't work.
Old Dec 12, 2019 | 02:22 PM
Hot Rod Roy's Avatar
Hot Rod Roy
What year Corvette?
The manual control **** is on the bottom of the motor only for the '84 - '87. The **** is on the top of the motor for the '88 - '96.
Old Dec 12, 2019 | 02:29 PM
marjoy01's Avatar
marjoy01
3rd Gear
Thanks for your reply! I did know about the **** for manual rotation however the gears won't engage. As a result I am unable to retract the headlight. I don't believe I can remove the headlight assembly without retracting the headlight. Has anyone else run into this problem. Thanks!
Old Dec 13, 2019 | 01:51 AM
Hot Rod Roy
Again: What year Corvette? It makes a difference! We're here to help, but we're not psychic!
Old Dec 13, 2019 | 07:39 AM
marjoy01's Avatar
marjoy01
3rd Gear
Sorry about that! It is a 1994 Corvette. As I indicated the manual **** does not work and I am unable to retract the headlight. I do not want to damage the assembly. Perhaps there is some other way to retract it. Please advise and thanks for any help you can give!
To C4 Headlight Problem - Please help!
