Probably a Dumb Question
Old Dec 19, 2019 | 08:41 PM
Regen's Avatar
Regen
Default Probably a Dumb Question
I have an 87 coupe. Thinking about having a set of Flowmaster 40 series put on in the spring. Just the mufflers for sound, axle back.
Is a flowmaster a flowmaster a flowmaster or do I need to find a set designed to fit my car?
I ask because I see lots of places that sell them but everytime I put my make and model in, the site says that I have to call.
Any advice on where to buy?
Old Dec 19, 2019 | 09:18 PM
FAUEE's Avatar
FAUEE
Those are designed as custom fit mufflers. You're best off letting the shop doing the cutting and welding decide.
Old Dec 19, 2019 | 09:49 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Best do a search here and find comments from others on Flowmasters.
Seems those have a reputation for generating a "drone" that is unacceptable for some.
Corsa's have a better rep for sound and less drone.
Old Dec 19, 2019 | 10:07 PM
jv9999's Avatar
jv9999
I have Flowmaster 40's on my '87 convertible. I don't find them to be objectionable at all. I still have the original pre-cats and the main cat, so that might be a consideration.
Old Dec 19, 2019 | 10:24 PM
Regen's Avatar
Regen
Yeah if that matters, I still have to pass emissions where I live. (Already passed for this year and next). All of the rest of the stock exhaust will remain in place.
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Flowmaster's come in at least six different versions. So, a Flowmaster is not a Flowmaster is not a Flowmaster. You need to determine the length, inlet and outlet positioning, and inlet and outlet sizes for your car if you have it narrowed down to the 40 Series muffler.
By the way, it seems that 'drone' appears to be a problem with almost any muffler that has a flat case. An oval-cased muffler like the Corsa or the stock muffler seems to be immune to the dreaded drone. I believe that this is because a flat case can vibrate like a drumhead when excited by power pulses, whereas an oval case cannot vibrate, at least not at the low frequency produced by our engines.
Old Dec 19, 2019 | 11:13 PM
FAUEE's Avatar
FAUEE
Interesting thought. If you're right, welding in some support brackets could keep the drone from happening.
Old Dec 19, 2019 | 11:49 PM
Regen's Avatar
Regen
OK, thank you.
Old Dec 20, 2019 | 01:53 AM
ZHammer's Avatar
ZHammer
Listen to the coach, he is spot on on this matter.
Old Dec 20, 2019 | 11:20 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Old Dec 20, 2019 | 11:24 AM
BLUE1972's Avatar
BLUE1972
Be careful with the muffler choice, the drone can drive you nuts... I have an 85 and it's bad on the highway in 6th gear.
Old Dec 23, 2019 | 06:14 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I bought Corvette Central mufflers for my 87 vert. They are made by Magnaflow and fit perfectly. Very mellow and powerful sound. I had muffler eliminators on the car before that and they were LOUD!. I bought a cat less front Y pipe and used a Magnaflow high flow cat and a rear Y pipe with an H pipe built in. I was very happy with the results.
To Probably a Dumb Question
