granitelli maf sensor
Old Nov 17, 2002 | 07:24 PM
sal.b's Avatar
sal.b
6th Gear
Default granitelli maf sensor
has anyone put one in their vette?is it worth 300.00.1994 lt1 help
Old Nov 17, 2002 | 10:11 PM
sal.b's Avatar
sal.b
6th Gear
Default Re: granitelli maf sensor (sal.b)
dont understand havent gotten any replies...anyone have one in thier vette?
Old Nov 18, 2002 | 12:08 AM
GDP's Avatar
GDP
Not worth any money. I ported and polished my own MAF housing, works great. HOWEVER the results are temporary unless you have a chip or a reprogrammer, whichever may apply to you.
EDIT: Here's a link you can follow to learn how to do your own and save the $300.00 they charge, the main difference I followed is that my friend has the single best tool you can ever use for any type of aluminum grinding, called an air dye. If you have an air compressor, I highly suggest buying one at the local hardware store for abotu $50.00 and a tip for grinding aluminum. Saved countless hours worth of sanding. Here's the link:
http://installuniversity.com/install...afapalooza.htm
EDIT #2: Here's a link to the post I made after I did my own, contains pictures of before, current, and what I plan to do soon: http://forums.corvetteforum.com/zerothread?id=426891
[Modified by GDP, 11:14 PM 11/17/2002]
To granitelli maf sensor
