heater control vavle
Old Dec 31, 2019 | 01:13 PM
phat87's Avatar
phat87
2021 C4 of the Year - Unmodified Finalist
Default heater control vavle
Howdy Crew, I'm looking for a repair kit for my 87 heater control valve. The part number I found from the Forum posts is a Four Seasons 74800. I tried to find it on Ebay, no luck. If anyone can direct to where to buy one it would certain;y be appreciated. The OEM P/N is for the whole ***'t is 14079882 which is supposed to cross to a Delco 15-5389 but the place sI have called say that # is not valid. Thanks kids.
Old Dec 31, 2019 | 02:04 PM
phat87's Avatar
phat87
I found the info I was looking for. I went on Ebay instead of Amazon. Much better results. If anyone can confirm that is indeed the unit I need for 87 appreciated. Thanks.
Old Dec 31, 2019 | 06:20 PM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
On your ebay search did you use the search argument: 1987 corvette heater control valve with nipple ??? Man those are PRICEY!!!
I believe 1984 and 85 did not have the nipple on the heater pipes, and 1986 and 1987 definitely did. On my '87, I was still able to get the SMP 74800 but as you found those are no longer available.
When my '86 started leaking this spring, I I took a different and much more affordable approach. As I wished to keep the nipple in place for the line to the intake manifold, I purchased a
Four Seasons 74612 Heater Valve Four Seasons 74612 Heater Valve
and installed it like so:
I think I paid a little over $8.00 at the time for the valve and I already had some 5/8" & 3/4" heater hose to plumb it in. It worked PERFECTLY all summer long - as I expected it would. I saved a bundle and I will never have to worry about a leak there again.
Old Dec 31, 2019 | 10:40 PM
Hot Rod Roy's Avatar
Hot Rod Roy
The Four Seasons 74800 valve is quite different than the stock '87 valve. To repair your original valve, you use only the core of the 74800 to replace the core of the original valve, usually because the original valve is leaking at the seal of the actuating shaft, which is part of the core.
The 74800 has FOUR ports, and includes the coolant bypass tube, so the tube that Red86 is calling the "nipple" is not required. I don't know how this "nipple" water tube is connected in your '87.
I used the entire 74800 valve in my '84. The hose from the back of my intake manifold, which is fed from the back of the heads. goes directly to my new valve. The outlet hose from the heater core goes thru the valve to my water pump. When the valve is OFF, coolant flows thru the bypass tube of the 7400, but not thru thru the heater core. When the valve is ON, coolant flows thru the heater core, but not thru the bypass tube.
Old Jan 1, 2020 | 05:50 PM
phat87's Avatar
phat87
Thanks Hot Rod et al, I agree it is just the guts of the 74800 that I will use. Hot Rod mine is exactly as seen in your photo. Thanks for that.
Old Jan 11, 2021 | 03:15 PM
Elijah Collins's Avatar
Elijah Collins
3rd Gear
How does this work on the 84? Since this valve has 4 stems while the factory one only has 3?
To heater control vavle
