My 84 project
A guy locally has a Renegade and loves it so far on his 3rd gen camaro. He said it pulls all the way to redline like a train now, but here's the kicker. He asked me today if there is any issue with it running very lean with the airbox installed? Wha?! I replied, not that I have ever heard of or know of. He said if he takes the airbox off it runs just fine, put it back on and it bogs very badly at WOT. I asked him a few questions and said it is going way lean for some reason and it is mostly likely something simple.
So today he send me another text and said he fixed it. Found out that his flapper valve in the hood was staying closed because it was out of adjustment. So he was only getting air via the small end of the snorkel at WOT. He said it runs like a train again like when the airbox was off. Just another odd issue and was a coincidental issue after a Renegade install, it's always something, but one I have never encountered.
I have had a huge flooring project going on here for the last three weeks, I'm wore out, but it is done finally. What a job and strain.
The pay was stellar though and can't complain about that, but the work load was horrible, not to mention getting shot at or a rocket/mortar attack thrown in for good measure. Never a dull moment in the Stan, Iraq or Kuwait.
I did the 16s when I did construction. 14-16 hour days a lot of it just straight trenching. Never will I ever go back. That sucked and didn't pay but it did get me to where I'm at now. Also, thank you for your contract work Tom, I have a friend who did that with Honeywell years back so I appreciate what that takes to do.
Back somewhat on topic for a moment. I have no clue what's up with my ported manifold. I'll probably call my welder this week as it's been 3 months now. Curious more than anything now. And i want to get my parts on before spring so I can reach out to Rob if he's available and willing. It would be amazing to have a whole summer where I can just drive the car for once lol.
As far as the new mill, found a really nice set of rods for a really nice price so that's fun. Haven't decided if I'll do a street solid roller custom grind or if I'll just end up with a hydraulic. It all depends. But more on that coming as it comes.
I also increased base timing by a couple degrees to 12. Seemed to help with the random misfires I was seeing at part throttle. Was reading about scatter and it would seem at 8 degrees and 45 total SA at light throttle it could occasionally jump around. Not really sure but it feels and looks better per my data logs. I want to set base at 14 because it started better with the increased base.
I'm running an 83.5 with the under drive so I'd have to go smaller yet.
Have fun on the "Loud Pedal".
Also, I have almost no DC at idle... so the lower pressure was to keep a somewhat stoich idle but with all the fueling it takes now down there I may be okay... worst case I can turn async back on.I'm going to shoot Rob a message over on third gen once I get all the little things fixed (like my belt alignment) Don't want to go out in a car that could have anything extra come up... I have to look at how the DC is calculated but it seems to be a multiplier on the VE table because wide open VE didn't increase as proportionally as the DC suggests fueling did. But if it multiplies then it makes sense.
Just out of curiosity, how close do you think I would be to the water jacket if I redrill the front accessory bolt hole below the thermostat?
Also, it's up in the air if it's permanently staying on. It appears to still be hitting the hood (albeit less than before) but I don't know. I want to test the one I hacked up and I will always have it in the back of my mind this one could leak vacuum from the lifter valley at anytime. But for now it stays and hopefully it proves me wrong and the thicker 1205 gasket holds it together. The prior one I used was a stock style steel laminate core type and the ports are slightly smaller than a 1205, but bigger than a 1204. The blue "seal" ring actually hit the flange this time instead of sitting above it so it should be okay. Wish a 1206 would fit, that's what the head opening is sized for but the misalignment between the two would never seal.
Again, thank you for your awesome product.
Sucks EMS just didn't care on the QC front. It is otherwise a 90% awesome piece for the price.
If you look at the flat area in front of the T-stat, that is about .5" thick(ish) and goes down in depth for about .75 or maybe even a tad deeper max .875". So, a .5" thickness isn't IMO a lot of material before hitting water for a bolt hole. I would be more comfortable with .75 or more for sure.
If Rob happens to come down to your area, which he may to do it in person, tell him I said hello. I have had several big projects that have been keeping me away from my car to finish things up 100% with Rob. I plan on doing more on the car soon and have some more items coming for it in shipping as well. Good luck with the tune tweak and I know you WILL be happy in the end.
I'll drive up to him even, he's 10 minutes or so from my aunt, about 20 from me. I'm very familiar with the area so it's fine. And I will tell him you said hello. I think, now would probably be a good time to source a dana 44... I foresee breaking the 36 quite easily now lol. Also, there may have been metal on the dipstick when I pulled it this morning to check it... So depending what tomorrows oil change brings everything might come to a halt... That 388 may come off the back burner sooner than anticipated.
I am hoping it was just the way the LED was reflecting off the end of the dipstick.If you're up for it and have the time, I may give you a call just to catch up maybe later this week or next, it's been a while and I'd love to hear all you've done since we last spoke. I've been reading up on the "blog" posts you've been leaving on the site but I know you have a lot more going on in the background too. I've been quite busy myself hence why this was done now. Work... well it sucks to say the least.
