AlV 88 C4 project
Old Jan 29, 2020 | 06:57 PM
AlV's Avatar
AlV
Originally Posted by FostersPerformance
So its one of those $100 covers? Mine has a crack and was debating if going that route was worth it. Im NOT paying 500 for a new one....Looks good in the pic. Fit ok? Is it plastic? Thanks
yes it is the $100 cover type, Like you I couldn’t find my way to pay the $500 for the repop unit because I had other needs and I was building a daily driver so it didn't have to be perfect.
So here is my take, it’s plastic molded to fit over the top like a cap. The fit and shape is not bad and it looks decent as you can see in the picture. The big thing with this product is preparing the old dash. Removing the loose crap and creating a good bonding surface.
I’m a bit of a creative problem solver so after I brushed off the loose stuff I got a can of spray foam to fill the big cracks then cut and shaped the foam to smooth the surface. Then I used marine grade silicone adhesive to bond the cap to the dash.
Initially my result was good but these cars are like terrariums and the dash takes a beating from the sun so I developed a small distortion where it didn’t bond well. It doesn’t bother me but it could have been prevented. In retrospect I would use a combination of 3m tape and ice the thing like a cake with the adhesive. LOL use clamps and boards to sandwich the thing to evenly distribute the pressure.
all that said... I would opt for a new dash if I was restoring it or if I wanted something perfect.
Old Jan 29, 2020 | 07:00 PM
AlV's Avatar
AlV
Originally Posted by vader86
Nor do you want to buy a new one, the new one never goes in like the old one came out. I thought it was a huge PITA on my 86 when I did this.
Thanks! that’s good to know. It’s likely I will end up buying one in the future.
Old Jan 29, 2020 | 07:13 PM
AlV's Avatar
AlV
Default Bumper clean up
A little soap/water and a black rattle can. Plus sand and polish on the fog light lenses.
before and after:
Old Jan 30, 2020 | 03:27 AM
ghoastrider1's Avatar
ghoastrider1
good idea to go with maco for the paint. Looks like a good job, now lets hope it stays on the car. You saved a bunch of money, I turned my 86 over to a friend for paint in his shop. $4,500 bucks later I drove it home. Good job your doing.,.
Old Jan 30, 2020 | 07:36 AM
AlV's Avatar
AlV
thanks. It helped that I did a lot of the sanding which reduced a lot of the prep work they needed to do. Its far from perfect and the fact is I was hoping to get 5 years out of it figuring if I end up liking the car I’ll treat it to something better. So far it’s been 2 years and the paint held up okay. It’s stays outside no cover. The damage on the nose was the result of someone backing in to me. I have some chips from parking in lots But all that said it looks way better than when I got it.
Old Feb 1, 2020 | 07:02 PM
AlV's Avatar
AlV
Default Hoover
The front end on the Vette is like a vacuum cleaner sucking everything up on the road and jamming it between the condenser and radiator. LOL
Old Feb 1, 2020 | 08:00 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
You can put a screen underneath to stop the leaves from getting in. Do a forum search to find out how.
Old Feb 1, 2020 | 08:36 PM
1993C4LT1's Avatar
1993C4LT1
Awesome
Old Feb 1, 2020 | 09:28 PM
AlV's Avatar
AlV
thanks for the tip.. I’ll definitely add it.
Old Feb 3, 2020 | 12:22 PM
jbrianfoto's Avatar
jbrianfoto
before and after:
Outstanding !
Old Feb 15, 2020 | 08:12 PM
AlV's Avatar
AlV
Default AC pull let’s get at er
Had to take a break because of a planned eye surgery but I’m back and better than before. Time to pick where I left off and pull that AC setup. Pitter patter let’s get at er.
Old Feb 23, 2020 | 11:45 AM
AlV's Avatar
AlV
Default Alternator and AIR removal
Pulled some more stuff out of the 88.
Old Feb 24, 2020 | 03:28 PM
  #33
AlV's Avatar
AlV
Default Now for something different.
My other ride.. in case you notice all that MOPAR stuff in my garage. LOL
Old Feb 24, 2020 | 10:09 PM
  #34
AlV's Avatar
AlV
Default Power steering pump and bracket removal
with the steering pump and bracket removed I can focus on the fuel lines, remaining AIR emissions line, vacuum lines and electrical connections.
Old Feb 29, 2020 | 11:38 AM
  #35
AlV's Avatar
AlV
Default Intermediate steering shaft, tensioner and bracket on deck.
Chugging along on this lil 88.
next up I pulled the remaining AIR lines, Tensioner, AC/tensioner bracket, lower radiator and heater hoses. Lastly the intermediate steering shaft.
Everything is so tight! They engineered a hole in the bracket to route a heater house. LOL
had to pull the tensioner off first then disconnect the heater hose. But you can’t pull that out because it’s T’es an connect to a line that runs under the engine. With the hose disconnect I loosened the nuts and bolts holding the bracket then I disconnected the fuel lines and shimmied it out around the hose and fuel lines. Dang! I would hate to have to replace a lower rad hose in this thing if it was all together. LOL
next up disconnect remaining electrical and vacuum.
Old Mar 14, 2020 | 01:39 PM
  #36
AlV's Avatar
AlV
Default Another step closer
Closer to driveline separation
Old Mar 19, 2020 | 08:03 PM
  #37
AlV's Avatar
AlV
Default Bye bye braces and exhaust
I decided to remove the exhaust and dean braces to help facilitate separation and provide access to the shifter.
To AlV 88 C4 project
Old Apr 5, 2020 | 05:42 AM
  #38
AlV's Avatar
AlV
Default 14 bolts away from separation
Pretty sure I’ve got it all ready for lift off.
later today I’ll drop it on stands pull the 8 engine cradle bolts then the bolts for the bat wing and trailing arms.
Old Apr 5, 2020 | 08:09 AM
  #39
mazdaverx7's Avatar
mazdaverx7
Are you removing the engine or the trans? last I remember you were just removing the A.C.
Old Apr 5, 2020 | 08:20 PM
  #40
AlV's Avatar
AlV
removing the whole driveline to rebuild everything actually I’m probably not going to rebuild the DN. I’ve decided to replace it with a TKO 5 speed.
