Distributor wiring question
Old Feb 8, 2020 | 04:49 PM
Greg Humphrey's Avatar
Greg Humphrey
7th Gear
Default Distributor wiring question
On the harnesses for the distributor where does the white wire with the spade go?
Old Feb 8, 2020 | 07:06 PM
Greg Humphrey
7th Gear
I think I found the answer that it is a test plug
Old Feb 8, 2020 | 09:46 PM
Hot Rod Roy's Avatar
Hot Rod Roy
You are correct! The factory uses that plug, but it stays empty after that testing is complete.
To Distributor wiring question
