Help with this part plz.
Old Feb 22, 2020 | 01:30 PM
Jim Crisp's Avatar
Jim Crisp
6th Gear
Default Help with this part plz.
so for some reason the car started working.....idk must 2 have been vapor locked but thanks for helping me
Old Feb 22, 2020 | 09:52 PM
corvette95's Avatar
corvette95
Need a wider shot. Maybe coolant temp sensor. Rent a fuel pressure gauge and see if you have fuel pressure when it turns over.
Old Feb 22, 2020 | 11:55 PM
jv9999's Avatar
jv9999
I think that's for your missing EGR solenoid. Probably not related to your problem. Check for spark, fuel pressure, and injector pulses.
Old Feb 23, 2020 | 05:33 PM
Jim Crisp's Avatar
Jim Crisp
6th Gear
Originally Posted by ihatebarkingdogs
If it IS the EGR solenoid, and those exposed pins shorted to ground, it would blow a fuse that could result in a no-start. I don't have my books with me, but in a 91 I believe it will be GAUGES, A/C, IGN 1, fuse. Check the pin with the pink/blk wire for voltage with the key = ON. If there is no voltage, check fuses.
thanks my fuse box is ticking also and my battery is drained as well.
Old Feb 23, 2020 | 06:13 PM
firefighter12986's Avatar
firefighter12986
Start with the basics need to know what your missing fuel or spark its a guessing game until we know at least this
Old Feb 23, 2020 | 09:32 PM
Jim Crisp's Avatar
Jim Crisp
6th Gear
Well i can start the car with starter fluid but a real rough idle and if i dont press the gas it dies but i cant get it above 1000rpms or it backfires.
Old Feb 24, 2020 | 02:42 PM
Jim Crisp's Avatar
Jim Crisp
6th Gear
so i checked my fuses and the gauges one was bad so i replaced it and it still doing the same thing.
To Help with this part plz.
