94 C4 will not start
I was just informed the computer controls the injectors via the ground, so I have purchased a test kit and will test the connections once again.
If this is not the problem all I can try next is the fuel pressure regulator.
Please let me know if anyone has any other thoughts.
Thanks!
Last edited by Anthony 94Vette; Feb 25, 2020 at 10:54 PM. Reason: Add more information
Not sure what else it could be?
Could it be the security system possibly the chip on the key is bad?
If anyone has any advice I would appreciate it!
FYI - I was told if one injector is bad the vette will shut down the entire bank. I will ohm test the injectors soon. I believe all of the testing I have done leaves me with only two remaining possibilities...
1) A bad injector (I need to check on what is the correct ohm reading).
2) A bad computer.
I am leaning towards the injector as the computer has control of the injectors.
To Be Continued....
I checked each injector and all provided a reading of 12.2 ohms.
I also checked the codes and received the following:
Bank#1: C12
Bank#4: - - -
Bank#9: - - -
I also tested my battery it showed 11.99 volts.
From what I was told, it could be the computer.
Does anyone have any other thoughts?
As always I appreciate everyone taking the time to assist me!
The car does not start however, the fuel presser is about 43-45 after I crank the engine.
FYI - when I changed the fuel regulator there was plenty of gas in the fuel rail.
Bank#1: C12
Bank#4: - - -
Bank#9: - - -
The car will start if I spray starter fluid, but will dye when I stop spraying the starter fluid.
Thank you for your time!
1) I put a pressure gauge on fuel rail and it showed 45psi.
2) I then thought it could be the coil or the ICM, so I put an inline tester on the coil and a few spark plugs and they all had spark.
3) I tried starting fluid and the car started then died.
4) I then checked each of the fuel injector connections for power and all had power.
5) I was informed the computer controls the injectors via the ground, so I purchased a test kit and tested the connections once again and found the computer is controlling the injectors (the light blinks when trying to start the engine).
6) I then replaced the fuel pressure regulator and she still will not start.
7) I was then told if one injector is bad the vette will shut down the entire bank to protect the engine, so I performed an ohm test on all of the injectors and the reading was 12.2 for each. I am not sure what the proper reading should be for the injectors, but have heard if it you get less than 10 ohms the injector is bad.
8) I also checked the codes and received the following:
Bank#1: C12 (On-board diagnostics no codes)
Bank#4: - - -
Bank#9: - - -
9) I also tested my battery it showed 11.99 volts. Just be see if it is the battery, I have charged it and used the charger in assist start mode and she still will not start.
10) I then thought if it could be the VAT system/security system. However, everything I have read states the engine would not crank if this was the problem and she does crank, so I have eliminated this possibility.
I was told by another vette owner that it could be the computer. However, the computer appears to have control of the injectors when I tested each of them.
I am not sure what else it could be?
I will need to get back to you regarding how long the pressure holds after trying to start the car as I have not timed it. I assume 30 minutes would be enough of a test?
With regards to pulling the codes manually, I will need to try that and get back to you as well (how do I perform this?).
The car has always run well until this issue.
I have a 94 6 speed base model.
Thanks!
I finally figured out what was wrong with the car.
I have water in my gas tank. I assume it got into the tank after a heavy rain. The gas cap was loose and the drain was clogged. I believe there was a water buildup which found its way into the gas take.
So far I have pumped all of the fuel out of the tank and let the cap off to possibly allow what is left to evaporate.
Does anyone have any suggestions as to how I should continue and what kind of damage I may have with regards to the fuel system due to the water?
Thanks!
Thanks!
My '96 LT4 was sitting outside, under trees (such DIRTY trees!), uncovered for over one year. The fuel hatch compartment was full of tree stuff and the drain couldn't let the water out. Sound familiar? Over months of rain and temperature and atmospheric pressure changes the gas tank sucked in over TWO GALLONS of water! I have photos to prove it. The fuel pump was not too happy pumping that water and probably partially seized in the process blowing the fuse.
I ended up siphoning all the residual water out of the bottom of the tank along with around 15 gal of old gas and into multiple buckets and clear containers. Adding some denatured alcohol to the gas forced the water to separate out much easier than I thought and also allowed me to return ethanol-free (but old) gas back into the tank. My siphon consisted of several sections of tubing, the first was a plastic plumbing pipe used to connect sink faucets to the water supply shutoff valve. This was an important tube because it was straight and easy to place exactly where I wanted it to be on the tank floor. Flexible hose isn't easy to control and difficult to make sure it's touching the areas you want. Connected to that pipe was maybe 5 feet of 3/8" black, rubber fuel line. To start the siphon I connected a Harbor Freight siphon pump then pulled it out of the way when the fuel started flowing. Yeah, this is a pretty dangerous operation so I don't recommend it unless you can watch all your operations carefully and keep a gasoline-rated fire extinguisher at hand.
Done, and after adding the clean gas back in the tank, I immediately fired up the engine and let it run for a while to help purge any last traces of water from the fuel injectors and fuel rail. Rust forms very quickly in a fuel injection system and I wasn't going to let even one day go by knowing what was possibly still in the lines. Eventually I replaced the fuel pump, finger strainer and main fuel filter. Don't wait long to replace those parts. There's a towing bill just waiting to happen if you leave the old parts there.
Good luck!
