ac help
Old Mar 4, 2020 | 09:25 PM
new2me92's Avatar
new2me92
Default ac help
i need to change the clutch on the ac compressor on my 92 vette. Can it be done without removing the two hard lines coming out the top of the compressor. hoping to do this without evacuating the freon. has any one done this. thanks for any help Don
Old Mar 6, 2020 | 06:35 AM
mazdaverx7's Avatar
mazdaverx7
I recommend having the refrigerant recovered by an a.c. machine and then removing the compressor from the the engine. You will want the compressor on the bench for a clutch replacement.
Old Mar 6, 2020 | 08:20 AM
pherr's Avatar
pherr
You can do this with the compressor on. You don't have to discharge the system. I just did mine back in Nov. I replace the clutch and pull bearing. Took about 30 mins. Depending on the compressor, different years, some you have to have a clutch removal tool. My 90 did not, only a snap ring. From one to ten this is about a 3 if you are mechanical.
Old Mar 7, 2020 | 03:20 PM
bac22's Avatar
bac22
Get a decent pair of snap ring pliers, otherwise it's a fairly easy job to replace.
To ac help
