Driver door
Old Mar 11, 2020 | 09:38 PM
auggy's Avatar
auggy
Default Driver door
My 94 coupes driver door has migrated and has to pulled in about an eight of an inch back towards the body. I have tried to move the post inward after loosening it but it won't budge towards the body. I don't like the idea of loosening the 3 hex screws on the door to move the latch. They are on very tight. Not sure that would work anyway. Any thoughts would be appreciated. Thanks
Old Mar 12, 2020 | 02:38 PM
corvette95's Avatar
corvette95
striker adjustment or hinges may be worn. Even the latch mechanism. Hard to to without seeing and feeling the slack movement
Old Mar 12, 2020 | 02:46 PM
auggy's Avatar
auggy
Too much slack. I'M going to shim the striker post on one side to get it to angle in . Tried moving the latch mechanism but looks like no adjustment is possible.
Old Mar 12, 2020 | 02:47 PM
corvette95's Avatar
corvette95
I would look at the hinges closely first, that is usually the problem .
Old Mar 12, 2020 | 02:53 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
The hinge pins can wear over time. How to replace them has been covered several times here over the past few years.
Old Mar 12, 2020 | 06:02 PM
auggy's Avatar
auggy
Wouldn't the hinge pins draw only the front of the door towards the body of the car ? My problem is play near the latch.. The door ajar light started flickering.
To Driver door
