Question
Old Mar 19, 2020 | 04:48 PM
85Vetteman's Avatar
85Vetteman
Default Question
IS THE ATTACHED PHOTO OF MY RPM READING GOOD OR NORMAL IN YOUR OPINION.. EVERYTHING IS RUNNING SMOOTH, THE RPMs SHOWN IS WITH THE CAR IS JUST ABOUT UP TO TEMPERATURE. I JUST FINISHED INSTALLING NEW INJECTORS, NEW FUEL PRESSURE REGULATOR, NEW IAC VALVE, NEW TPS. REBUILT THE THROTTLE BODY. ALL NEW VACUUM HOSES, NEW SMOG PUMP AND CANISTER...NEW PLUGS, WIRES AND CAP.
Old Mar 19, 2020 | 05:56 PM
Kmcoldcars's Avatar
Kmcoldcars
If your car is at idle and fully warmed up I think the idle should be about 500 to 650 rpm. The oil pressure reading is way high. It looks like you need a new sending gauge for that. However, all my experience is with 91 and 92 C4s.
Old Mar 19, 2020 | 06:02 PM
85Vetteman's Avatar
85Vetteman
I could be wrong on the car being up to temp The oil pressure does come way down to normal. My concern is the gauge RPM, if that looks good. Yes I know the car RPMs should be about 650. Just checking if my gauge is working correctly
To Question
