Headlight motor knocking
Old Mar 20, 2020 | 01:21 PM
CameronPiggot's Avatar
CameronPiggot
7th Gear
Default Headlight motor knocking
When I shut my headlights off, the drivers side headlight makes this REALLY loud knocking noise in closing position, and it doesn’t stop until unplugged. Does anyone know if it’s the gear that’s gone or maybe the bushings. Can someone let me know, cause I’m not sure what’s going on. This only happens when I’m closing the headlight not when opening. Thanks let me know
Old Mar 20, 2020 | 01:34 PM
Hardway's Avatar
Hardway
Its definitely the bushings. Check out my repair thread below. I just did this a few weeks ago. Set aside an hour or two to do both headlights. Not that hard, just a little finicky and time consuming.
https://www.corvetteforum.com/forums...ir-thread.html
Old Mar 20, 2020 | 01:38 PM
CameronPiggot
7th Gear
thank you!
Old Mar 20, 2020 | 04:06 PM
Warren Seale's Avatar
Warren Seale
This 4 part video is very helpful.
Old Mar 20, 2020 | 05:25 PM
CameronPiggot
7th Gear
is it just the bushings or should I replace the gear as well?
Old Mar 20, 2020 | 05:42 PM
auggy's Avatar
auggy
Don't replace the gears unless you have to. Inspect them when you open it up.
Old Mar 20, 2020 | 06:25 PM
Hardway's Avatar
Hardway
As Auggy said, buy the bushings first and have them on hand when you open them up. 95% of these motors just need the bushings. If gears are needed you can cross that bridge when you get there.
Old Mar 20, 2020 | 06:33 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Most important tool if you are doing it yourself, is 5/16 punch to remove roll pin.
To Headlight motor knocking
