Front spring isolators/pads... replace them?
Old Mar 25, 2020 | 09:14 PM
PacerX's Avatar
PacerX
Default Front spring isolators/pads... replace them?
Do these things ever go bad?
I'm rebuilding the entire front suspension on my 85 right now, and I think these are the only parts I haven't got. The ones on the car look a little cracked at the A-arms.
Is there a source?
Old Mar 25, 2020 | 09:24 PM
Kevova's Avatar
Kevova
You will have to fab them. VBP sold spring tip.pads, but they closdd a year or so ago.
Old Mar 29, 2020 | 12:10 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Unless brake or shock fluid has destroyed the rubber, No need to bother
Old Mar 29, 2020 | 12:41 AM
Gibbles's Avatar
Gibbles
I have never seen those available yet.
Should be fine unless totally gone.
if gone, best bet may be to find some used ones...
Old Mar 29, 2020 | 12:37 PM
Kevova's Avatar
Kevova
You would be lucky to get one of intact without destroying the spring it was on. The couple 2 inch pieces of flat hard rubber glued to ends would work.
Old Apr 2, 2020 | 10:24 PM
dizwiz24's Avatar
dizwiz24
Need to bring BACK VBP !
Old Apr 3, 2020 | 08:30 AM
aklim's Avatar
aklim
Did you check the usual sources? If I can replace 30 year old rubber, I would if I was there. Which piece is it?
Old Apr 3, 2020 | 08:31 AM
aklim's Avatar
aklim
You are full of great ideas. Unfortunately, mouth alone, unless you are a hooker (not judging) don't get the job done.
To Front spring isolators/pads... replace them?
