Please help
Old May 14, 2020 | 08:53 PM
Jerry Markham Jr's Avatar
Jerry Markham Jr
1st Gear
Default Please help
I just bought a 1984 corvette wasn’t running. It’s now running after due pump, fuel filter, plugs, cap, rotor, TPS, and map sensor have been replaced. Getting .52 at TPS closed. Ideals good but when warm car dies on acceleration. Getting codes 22 and 34.
Old May 15, 2020 | 04:53 PM
WarlockIII's Avatar
WarlockIII
Check this thread
https://www.corvetteforum.com/forums...4-43-66-a.html
Old May 15, 2020 | 07:34 PM
wilcar's Avatar
wilcar
My 84 had same problem, replaced same things you have. A friend had same problem with his cross fire camaro and was a bad ignition module. May not be your problem but not that hard or expensive to replace. ICM solved my problem. Now I run a carb and points distributor on my C4...no more problems with all the electronic stuff!
To Please help
