T-Top
Old May 25, 2020 | 11:38 AM
Rolf3212's Avatar
Rolf3212
Default T-Top
Is there a way I can remove the scratches from my 1996 Vette?
Old May 25, 2020 | 02:55 PM
Kmcoldcars's Avatar
Kmcoldcars
If you mean remove scratches from the clear targa top, the answer is yes. You can buff out the scratches if they are not too deep. You will probably buff through a clear coating on the targa top. If so, you will probably want to buff it off the entire top. It should cause no problems. If the scratches are deep you will need to sand them out with 1000 grit sandpaper and water. Then sand with 2000 and then 3000, with water, and then buff.
I had some deep scratches on my clear targa top. I sanded the scratches and then buffed the clear coating off the entire top. This was several years ago and it still looks great.
You need to be more specific with your questions.
Old May 25, 2020 | 08:18 PM
ACMX92's Avatar
ACMX92
2026 Corvette of the Year Finalist - Modified
2025 C4 of the Year Winner - Modified
2021 C4 of the Year Finalist - Modified
After sanding and buffing the scratches, would it be worth spraying clear back over the top? Will the acrylic discolor over time without clearcoat protection? I have a top with some light crazing and some scratches on the outside.
It would be worth the effort trying to fix it myself if that means not spending $200-$600 having the acrylic replaced.
Old May 29, 2020 | 12:41 PM
Rolf3212's Avatar
Rolf3212
Thank you
Old May 29, 2020 | 12:47 PM
Rolf3212's Avatar
Rolf3212
I posted this question again before I located this great answer.
To T-Top
