idle problam
Old Nov 25, 2002 | 05:08 PM
TopSpeedc4vette's Avatar
TopSpeedc4vette
Default idle problam
my car idles at 1100 to 1200 rpm. this didnt happen when i replaced the tps sensor and now with a new one it idle that high now. what the problam? do u guys know
Old Nov 25, 2002 | 05:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: idle problam (TopSpeedc4vette)
You need to set base idle with the IAC pintel fully extended and then set the base TPS value between .54Vdc and .65Vdc, assuring that the WOT reading is as high as possible (around 4.0Vdc or greater), method is on my site.
