Lt1 intakes
Should have some more updates soon.
I am also going to use this as an opportunity to improve the IAT placement. GM installed it at the throttle body for manufacturing ease, we don't need to worry about that so we will locate it closer to the air filter for a more accurate reading. Will use an iat extension to make the new iat location far closer to the filter.
A few things I've learned. There is really not much room between the rad shroud and hood, I suspect this was a big driver of intake design. My design does actually hit at the silicone coupler, but it's soft so there's no issue. If I was doing it over again, I would use a smaller cone filter, my filter fits, but it did make for a bit of a pain to do. The other option would be to reduce the pipe diameter, which if one were making a mass produced intake would be the ticket.
I don't expect this picked up any sizeable Performance boost. That said, it's a washable filter, makes the cool suckling noise of an intake, and it does feel like throttle response is a bit more eager. For about 80 bucks, I'm satisfied, and I have enough abs pipe left over to swap out the intake silencer on my truck too.
If not their tuners name would be mudd. GM knows what they are doing. no way an element adds 30+to the tire lol
