1994 corvette fx3 shock question
Old Jun 11, 2020 | 01:13 PM
jeff in indy's Avatar
jeff in indy
5th Gear
Default 1994 corvette fx3 shock question
My ride control idiot light came on a few days ago. After checking codes it said left rear shock. I removed the shock and the gear and actuator appeared fine but the gear spun 360 degrees on the shock. Upon closer inspection I can now see that the gear has a broken stop at the bottom of it. New gears are easily available for 40 dollars so should be easy fix. But I spun the gear back and forth several times on the shock before I realized the stop is what was broken. How do I know where to set the shock before installing a new gear or does it matter? It appears to me that the gear should only rotate 180 degrees back and forth and I have lost my starting point
Jeff
Old Jun 14, 2020 | 03:28 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
https://www.corvetteactioncenter.com...fx3/index.html
Old Jun 14, 2020 | 04:20 PM
ChumpVette's Avatar
ChumpVette
The gear can be replaced in either position without affecting the operation of the shock.
Old Jun 14, 2020 | 06:54 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
The new gear is held onto the shock with a tiny steel pin. Careful ..... they are REALLY easy to loose.
To 1994 corvette fx3 shock question
