C4 wheels
Old Jun 25, 2020 | 04:14 PM
chequey's Avatar
chequey
2nd Gear
Default C4 wheels
Hi,
Simple question: will the "Sawblade" wheels from a '91 C4 fit ok on an '86 C4?
Thanks.
Old Jun 25, 2020 | 04:21 PM
90vet's Avatar
90vet
sure will
Old Jun 25, 2020 | 11:39 PM
chequey's Avatar
chequey
2nd Gear
Thanks.
Old Jun 26, 2020 | 12:15 AM
convas's Avatar
convas
Originally Posted by 90vet
sure will
spacers ?
Old Jun 26, 2020 | 08:49 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
They will sit inboard of your stock wheels by about 3/4" due to the differences in offset.
I am not sure if they will rub on the inside or not, but some people seem to have used them without problems.
I put '93-'96 sawblades on my '85, but I used spacers. I had some 1 1/.4" spacers so I used those. They are wide enough to clear the stock studs, and worked fine for me. However I had the 8.5" front wheels and they were pushed as far outboard as I would want. I suspect the 9.5" like on the '91 fronts, would be a little too far outboard with that size spacer.
My '85 is shown below.
Good luck.
To C4 wheels
