upgrade exhaust
Old Jul 2, 2020 | 11:23 AM
wood78221's Avatar
wood78221
Default upgrade exhaust
After replacing the exhaust (going to Borla or Corsa) on my 94', I am wondering is there any additional modifications (tuning, computer work) to the engine that should be made to maximize performance? Thanks
Old Jul 2, 2020 | 11:32 AM
84 4+3's Avatar
84 4+3
Not particularly. If you did a full system with headers then sure but if you're just doing a cat back its close enough the ecm will compensate.
Old Jul 2, 2020 | 11:37 AM
wood78221's Avatar
wood78221
If I went headers also, what would that include on the "engine tuning" end?
Old Jul 2, 2020 | 11:40 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Exhaust isn't going to make any power on an LT1. No tuning needed. Exhaust will give you sound, and looks.
Old Jul 2, 2020 | 11:41 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Not much, or no more than you might get from an optimized tune on a stock engine. *I* wouldn't bother.
Old Jul 2, 2020 | 12:27 PM
MatthewMiller's Avatar
MatthewMiller
I'm pretty sure that even with headers, a MAF-equipped car like yours should be able to accommodate any increased airflow without needing to be recalibrated.
Old Jul 2, 2020 | 12:58 PM
vette196's Avatar
vette196
Old Jul 2, 2020 | 03:23 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
If your 94 LT1 is stock .... your "stock dual exhaust" was non restrictive to begin with so the only thing you will change is the sound. My suggestion is to retain the stock cat back exhaust and spend your money on long tube headers. You'll get a lower deeper sound and no adjustment to the tune will be required until you change the cam.
Old Jul 3, 2020 | 06:36 AM
wood78221's Avatar
wood78221
yep that is the sound I’m looking for. I want to keep the drone down as much as possible.
Old Jul 5, 2020 | 01:20 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I have a Corsa on my '95 and a Borla on my '96. Both without any computer tuning done and they both run fine.
They sound different than stock, but there are lots of ways to make the sound different such as headers, mufflers, eliminators, removing cats, etc.
If there is any performance gain, it is minimal. Like others have said, it will mostly be for a different sound or appearance.
Good luck.
Old Jul 5, 2020 | 03:13 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Originally Posted by QCVette
I have a Corsa on my '95 and a Borla on my '96.....They sound different than stock,
If possible, could you do a quick video of the cars, side-by-side with the engine running? I'd love to be able to hear the difference.
Thanks for the consideration!
Old Jul 5, 2020 | 05:03 PM
wood78221's Avatar
wood78221
Thanks for all the replies. I think I am going to go with Long tube headers.
Old Jul 5, 2020 | 05:06 PM
84 4+3's Avatar
84 4+3
I forgot it was an LT1. Yea. No real gains to be had there other than sound unless its pretty well built up.
Old Jul 5, 2020 | 09:52 PM
ZWILDZR1's Avatar
ZWILDZR1
I put a B&B 3" on my 96 LT1. It was maybe a bit lower tone. That's about it. Like others have said looks and a little tone wise. I still have the factory 96 LT1 exhaust sitting in the barn for that car. Not the best money ever spent on a car that's for sure.
Old Jul 6, 2020 | 10:19 AM
RetroGuy's Avatar
RetroGuy
If you haven't already done this, perform the easy mods of opening up your stock air intake/filter box, and the Throttle Body coolant bypass. Both are easy inexpensive mods even if they only added 1 HP.
To upgrade exhaust
